Wireless Client unable to Connect with Second WLAN on WLC
I have faceing a issue on my wireless network. Before sharing i want to sahre my wireless network i have WLC 2504 and LAG is enable and Cisco 3600 series of APs. I have one SSID which is working fine but now i added a new SSID. At client end  i can see the SSID and it signals are excellent but when i try to connect with new SSID after athentication key it prompt me Unable to connect i can figure it our what issue is???
i checked the key its correct.
Hall of Fame Super Gold
Post the output to the command "debug client ".  Do this command when the client attempts to join the SSID.
VIP Purple
Re: Wireless Client unable to Connect with Second WLAN on WLC
Paste the logs as asked by Leo...
Thanks Leo and Sandeep problem was at client end unable to refresh dhcp. Problem Solved
Can you explain how to solved this problem?,
I have a very similar issue...
Thanks....
350
