Wireless Clients can't get DHCP address through ASA relay
Hello! I'm having trouble getting wireless clients an IP address from our Windows server through an ASA dhcp relay. Here's my basic setup:
Wifi client ---> 1042N AP ---> 2960 Switch ---> ASA 5520 ---> Win 2008 DHCP/RADIUS server
  • I have 4 SSIDs on separate VLANs.
  • I can get a DHCP IP on any the AP's native interfaces (if I set it to DHCP) but not on any clients that connect to that SSID assigned to it.
  • The clients authenticate to RADIUS (same server as DHCP) and the AP shows authenticated, but still no DHCP address.
  • Ports 67 & 68 are open on all VLANs on the ASA.
  • The switchport is trunked with a native VLAN.
  • Relaying is setup on the ASA for all of the VLAN interfaces.
  • All the interfaces on the AP have ip helper addresses pointing to the Windows Server.
  • The VLAN interfaces on the switch all have IP helper addresses pointing to the Windows Server.
Help? I'll post configs if anyone needs them.
  • Getting Started with Wireless
VIP Purple
You only need the ip helper on the L3 interface that terminates your Vlan. If the 2960 is not setup for L3 switching you should remove that config from the switch and the AP.
On the ASA you don't need to "open" or allow DHCP in any ACL, if you have that config it won't hurt, but it also won't help.
What could be wrong:
1) the DHCP-relay on the ASA
2) The bridge-group config on the AP
3) The switchports connecting the AP and the ASA.
Post the relevant config and then it should be possible to find out what's going wrong.
-- Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
Re: Wireless Clients can't get DHCP address through ASA relay
Hey Karsten, here are the goods:
AP Config full:
Current configuration : 6819 bytes
version 12.4
no service pad
service password-encryption
hostname DC-AP1
logging buffered 4096 debugging
logging rate-limit console 9
enable secret 5 scrubbed
aaa new-model
aaa group server radius rad_eap
server 192.168.20.10 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 mbssid
dot11 syslog
dot11 ssid DC_3
   vlan 195
   authentication open eap eap_methods
   authentication key-management wpa version 2
   mbssid guest-mode
dot11 ssid DC_2
   vlan 193
   mbssid guest-mode
dot11 ssid DC_3
   vlan 197
   mbssid guest-mode
dot11 ssid DC_1
   vlan 191
   mbssid guest-mode
username scrubbed password 7 scrubbed
bridge irb
interface Dot11Radio0
no ip address
ip helper-address 192.168.20.10
no ip route-cache
encryption vlan 191 mode ciphers aes-ccm
encryption vlan 193 mode ciphers aes-ccm
encryption vlan 195 mode ciphers aes-ccm
encryption vlan 197 mode ciphers aes-ccm
ssid DC_4
ssid DC_2
ssid DC_3
ssid DC_1
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.191
encapsulation dot1Q 191
no ip route-cache
bridge-group 191
bridge-group 191 subscriber-loop-control
bridge-group 191 block-unknown-source
no bridge-group 191 source-learning
no bridge-group 191 unicast-flooding
bridge-group 191 spanning-disabled
interface Dot11Radio0.193
encapsulation dot1Q 193
no ip route-cache
bridge-group 193
bridge-group 193 subscriber-loop-control
bridge-group 193 block-unknown-source
no bridge-group 193 source-learning
no bridge-group 193 unicast-flooding
bridge-group 193 spanning-disabled
interface Dot11Radio0.195
encapsulation dot1Q 195
no ip route-cache
bridge-group 195
bridge-group 195 subscriber-loop-control
bridge-group 195 block-unknown-source
no bridge-group 195 source-learning
no bridge-group 195 unicast-flooding
bridge-group 195 spanning-disabled
interface Dot11Radio0.197
encapsulation dot1Q 197
no ip route-cache
bridge-group 197
bridge-group 197 subscriber-loop-control
bridge-group 197 block-unknown-source
no bridge-group 197 source-learning
no bridge-group 197 unicast-flooding
bridge-group 197 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid DC_4
ssid DC_2
ssid DC_3
ssid DC_1
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.191
no ip route-cache
bridge-group 191
interface Dot11Radio1.193
no ip route-cache
bridge-group 193
interface Dot11Radio1.195
no ip route-cache
bridge-group 195
interface Dot11Radio1.197
no ip route-cache
bridge-group 197
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface GigabitEthernet0.191
no ip route-cache
bridge-group 191
interface GigabitEthernet0.193
no ip route-cache
bridge-group 193
interface GigabitEthernet0.195
no ip route-cache
bridge-group 195
interface GigabitEthernet0.197
no ip route-cache
bridge-group 197
interface BVI1
ip address dhcp
no ip route-cache
ip default-gateway 192.168.19.33
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
logging history size 100
snmp-server community cisco RO
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.20.10 auth-port 1645 acct-port 1646 key 7 083715540D48574115
radius-server vsa send accounting
bridge 1 route ip
line con 0
logging synchronous
line vty 0 4
logging synchronous
transport input all
end
Switch Config snippet:
interface GigabitEthernet1/0/45
description DC-AP1
switchport trunk native vlan 191
switchport trunk allowed vlan 191,193,195,197
switchport mode trunk
interface Vlan191
ip address 192.168.19.34 255.255.255.224
interface Vlan193
ip address 192.168.19.98 255.255.255.224
interface Vlan195
ip address 192.168.19.162 255.255.255.224
interface Vlan197
ip address 192.168.19.226 255.255.255.224
ASA Config snippet:
interface GigabitEthernet0/2
nameif DC-TRUNK
security-level 95
no ip address
interface GigabitEthernet0/2.191
description Room 1 - Wireless
vlan 191
nameif DC1B
security-level 95
ip address 192.168.19.33 255.255.255.224 standby 192.168.19.34
interface GigabitEthernet0/2.193
description Room 2 - Wireless
vlan 193
nameif DC2B
security-level 95
ip address 192.168.19.97 255.255.255.224 standby 192.168.19.98
interface GigabitEthernet0/2.195
description Room 3 Wireless
vlan 195
nameif DC3B
security-level 95
ip address 192.168.19.161 255.255.255.224
interface GigabitEthernet0/2.197
description Room 4 Wireless
vlan 197
nameif DC4B
security-level 95
ip address 192.168.19.225 255.255.255.224
object-group service DM_INLINE_UDP_2 udp
port-object eq 1812
port-object eq 1813
port-object eq radius
port-object eq radius-acct
object-group service DM_INLINE_UDP_4 udp
port-object eq 1812
port-object eq 1813
object-group service DM_INLINE_UDP_6 udp
port-object eq 1812
port-object eq 1813
object-group service DM_INLINE_UDP_8 udp
port-object eq 1812
port-object eq 1813
object-group network DM_INLINE_NETWORK_2
network-object 10.10.0.0 255.255.0.0
network-object 172.16.0.0 255.240.0.0
network-object 192.168.0.0 255.255.0.0
object-group network DM_INLINE_NETWORK_4
object-group network DM_INLINE_NETWORK_6
object-group network DM_INLINE_NETWORK_8
access-list DC1B_access_in remark Access to radius service from AP's
access-list DC1B_access_in extended permit udp 192.168.19.32 255.255.255.224 object ctvservices04 object-group DM_INLINE_UDP_10
access-list DC1B_access_in extended permit udp 192.168.19.32 255.255.255.224 object ctvservices03 object-group DM_INLINE_UDP_2
access-list DC1B_access_in remark DHCP
access-list DC1B_access_in extended permit object-group DM_INLINE_SERVICE_2 192.168.19.32 255.255.255.224 object ctvservices03
access-list DC1B_access_in remark Allow wireless to wired communications
access-list DC1B_access_in extended permit ip 192.168.19.32 255.255.255.224 192.168.19.0 255.255.255.224
access-list DC1B_access_in remark Block access to all internal subnets
access-list DC1B_access_in extended deny ip 192.168.19.32 255.255.255.224 object-group DM_INLINE_NETWORK_2
access-list DC1B_access_in extended permit ip any any
access-list DC2B_access_in extended permit udp 192.168.19.96 255.255.255.224 object ctvservices04 object-group DM_INLINE_UDP_12
access-list DC2B_access_in remark Access to radius service from AP's
access-list DC2B_access_in extended permit udp 192.168.19.96 255.255.255.224 object ctvservices03 object-group DM_INLINE_UDP_4
access-list DC2B_access_in remark DHCP
access-list DC2B_access_in extended permit object-group DM_INLINE_SERVICE_4 192.168.19.96 255.255.255.224 object ctvservices03
access-list DC2B_access_in remark Allow wireless to wired communications
access-list DC2B_access_in extended permit ip 192.168.19.96 255.255.255.224 192.168.19.64 255.255.255.224
access-list DC2B_access_in remark Block access to all internal subnets
access-list DC2B_access_in extended deny ip 192.168.19.96 255.255.255.224 object-group DM_INLINE_NETWORK_4
access-list DC2B_access_in extended permit ip any any
access-list DC3B_access_in remark Access to radius service from AP's
access-list DC3B_access_in extended permit udp 192.168.19.160 255.255.255.224 object ctvservices04 object-group DM_INLINE_UDP_14
access-list DC3B_access_in extended permit udp 192.168.19.160 255.255.255.224 object ctvservices03 object-group DM_INLINE_UDP_6
access-list DC3B_access_in remark DHCP
access-list DC3B_access_in extended permit object-group DM_INLINE_SERVICE_6 192.168.19.160 255.255.255.224 object ctvservices03
access-list DC3B_access_in remark Allow wireless to wired communications
access-list DC3B_access_in extended permit ip 192.168.19.160 255.255.255.224 192.168.19.128 255.255.255.224
access-list DC3B_access_in remark Block access to all internal subnets
access-list DC3B_access_in extended deny ip 192.168.19.160 255.255.255.224 object-group DM_INLINE_NETWORK_6
access-list DC3B_access_in extended permit ip any any
access-list DC4B_access_in remark Access to radius service from AP's
access-list DC4B_access_in extended permit udp 192.168.19.224 255.255.255.224 object ctvservices04 object-group DM_INLINE_UDP_16
access-list DC4B_access_in extended permit udp 192.168.19.224 255.255.255.224 object ctvservices03 object-group DM_INLINE_UDP_8
access-list DC4B_access_in remark DHCP
access-list DC4B_access_in extended permit object-group DM_INLINE_SERVICE_8 192.168.19.224 255.255.255.224 object ctvservices03
access-list DC4B_access_in remark Allow wireless to wired communications
access-list DC4B_access_in extended permit ip 192.168.19.224 255.255.255.224 192.168.19.192 255.255.255.224
access-list DC4B_access_in remark Block access to all internal subnets
access-list DC4B_access_in extended deny ip 192.168.19.224 255.255.255.224 object-group DM_INLINE_NETWORK_8
access-list DC4B_access_in extended permit ip any any
access-group DC1B_access_in in interface DC1B
access-group DC1B_access_in in interface DC2B
access-group DC1B_access_in in interface DC3B
access-group DC1B_access_in in interface DC5B
dhcpd dns 192.168.20.10 192.168.75.49 interface management
dhcpd domain blah.com interface management
dhcprelay server 192.168.20.10 inside-4  wired
dhcprelay enable DC1A
dhcprelay enable DC1B
dhcprelay enable DC2A
dhcprelay enable DC2B
dhcprelay enable DC3A
dhcprelay enable DC3B
dhcprelay enable DC4A
dhcprelay enable DC4B
dhcprelay timeout 60
dhcprelay information trust-all
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect sip
VIP Purple
when you do a "show vlan" on the switch, do you see all the vlans that are needed (191,193,195,197)?
I do.
DCSW1#show vlan
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/7, Gi1/0/8, Gi1/0/10
                                                Gi1/0/11, Gi1/0/12, Gi1/0/13
                                                Gi1/0/14, Gi1/0/15, Gi1/0/16
                                                Gi1/0/17, Gi1/0/18, Gi1/0/19
                                                Gi1/0/20, Gi1/0/21, Gi1/0/22
                                                Gi1/0/23, Gi1/0/24, Gi1/0/25
                                                Gi1/0/26, Gi1/0/27, Gi1/0/28
                                                Gi1/0/29, Gi1/0/30, Gi1/0/31
                                                Gi1/0/32, Gi1/0/33, Gi1/0/34
                                                Gi1/0/35, Gi1/0/36, Gi1/0/46
                                                Gi1/0/49, Gi1/0/50, Gi1/0/51
                                                Gi1/0/52
65   NETMGMT                 active
103  WIRED                   active
105  WIRELESS                active
106  GUEST                   active
190  CAPDC1A                          active    Gi1/0/1, Gi1/0/2, Gi1/0/3
                                                Gi1/0/4, Gi1/0/5
191  DC1B                          active
192  DC2A                          active    Gi1/0/6
193  DC2B                          active
194  DC3A                          active
195  DC3B                          active
196  DC4A                          active
197  DC4B                          active
222  VOICE                   active
251  PHONES                     active    Gi1/0/9, Gi1/0/37, Gi1/0/38
                                                Gi1/0/39, Gi1/0/40, Gi1/0/41
                                                Gi1/0/42, Gi1/0/43, Gi1/0/44
VIP Purple
I just realize that some of the IP-adresses on the switch are duplicates to the ones on the ASA. If you don't use the 2960 for routing (it doesn't seem so) it's best to remove all "interface vlan" from the switch and only keep the one you use for management. And remove all ip helpers on the switch and the AP if the relay is running on the ASA.
I've removed all switch and AP IP helpers and the VLAN interfaces. When I change the default gateway, on the AP, from the switch interface to the ASA's interface, it goes dark. Do you think this indicative of a routing problem on the ASA?
EDIT: I only removed the VLAN interfaces from the switch, not from the AP :-)
Message was edited by: Kevin Doran
VIP Purple
If you can work successfully in one VLAN, then the routing from the ASA to the DHCP-server should be fine. On the AP you get your mgmt-IP by DHCP, so you don't need the default-gateway at all. It will be provided by DHCP. Do a "debug dhcprelay event" and "debug dhcprelay packet" on the ASA and try again. You should see that some DHCP-packets gets processed by the ASA.
OK, we're getting close, here's the debugging:
DHCPD/RA:  Relay msg received, fip=ANY, fport=67 on DC1B interface
DHCP: Received a BOOTREQUEST from interface 4 (size = 307)
DHCPRA: relay binding found for client cc3a.6124.c7f6.
DHCPRA: setting giaddr to 192.168.19.33.
dhcpd_forward_request: request from cc3a.6124.c7f6 forwarded to 192.168.20.10.
DHCPD/RA: Punt 192.168.20.10/67 --> 192.168.19.33/67 to CP
DHCPD/RA:  Relay msg received, fip=ANY, fport=67 on inside-wired interface
DHCP: Received a BOOTREPLY from relay interface 11 (size = 316, xid = 0x2423c151) at 14:30:37 UTC Tue Nov 26 2013
DHCPD/RA: creating ARP entry (192.168.19.38, cc3a.6124.c7f6).
DHCPRA: forwarding reply to client cc3a.6124.c7f6.
This message appears over and over until the wifi client gives up. It looks like it's getting an IP (19.38) from the DHCP server, but it's still not getting back to the wireless client.
1229
