Wireless Clients cannot communicate to eachother.
I have a 871W router that I am having trouble getting wireless clients to communicate.
I can ping and use applications from any wired client to any wireless device. However I am unable to ping or use any other protacol from one wireless device to another.
I have confirmed that there is no firewalls on the endpoints blocking communication.
I have removed ACLs on the BVI1 interface but that had no affect.
Any assistance would be greatly appreciated.
Current configuration : 7670 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname cc-fw-router
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
enable secret 5 $1$crkU$2cWtWnMRjMvfo4ADb4pfi0
aaa new-model
aaa authentication login default local none
aaa session-id common
resource policy
clock timezone PCTime -5
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
ip subnet-zero
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.10.20.1
ip dhcp pool sdm-pool1
   import all
   network 10.10.20.0 255.255.255.0
   default-router 10.10.20.1
   dns-server 192.168.2.244 8.8.8.8
ip dhcp pool xbox
   host 10.10.20.20 255.255.255.0
   hardware-address 0100.1dd8.5b52.73 ieee802
   dns-server 192.168.2.251 4.2.2.2
ip inspect name DEFAULT100 cuseeme
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 icmp
ip inspect name DEFAULT100 netshow
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 esmtp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
ip tcp synwait-time 10
no ip bootp server
ip domain name yourdomain.com
ip name-server 4.2.2.2
ip ssh time-out 60
ip ssh authentication-retries 2
crypto pki trustpoint TP-self-signed-1816499983
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1816499983
revocation-check none
rsakeypair TP-self-signed-1816499983
crypto pki certificate chain TP-self-signed-1816499983
certificate self-signed 01
  30820252 308201BB A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31383136 34393939 3833301E 170D3038 30323039 32313436
  31395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 38313634
  39393938 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BD37 F594F5B4 726A60BA 2C99B43C 0DE6814A 17BB53C2 A2202828 D6AA7774
  7E3FF99D 7A6B06D8 C7A52D0E 2989CF78 F5E892C0 9A9DA783 1E6C8B59 6F8B01D7
  1E631226 D372D65B 6E72CA49 D572FEA6 26131F83 32F87678 4B13735F 383D9F65
  287E2CE3 46459CAD 582DB438 6E599885 BAE48719 4AC9EB73 8BC32114 C6C637C9
  80350203 010001A3 7A307830 0F060355 1D130101 FF040530 030101FF 30250603
  551D1104 1E301C82 1A63632D 66772D70 65746572 2E796F75 72646F6D 61696E2E
  636F6D30 1F060355 1D230418 30168014 391859D0 F5A8499D 8EF185B7 DC937161
  7F2B7CBA 301D0603 551D0E04 16041439 1859D0F5 A8499D8E F185B7DC 9371617F
  2B7CBA30 0D06092A 864886F7 0D010104 05000381 8100BC17 189FF9F1 01349085
  70E363E9 47AB7A9A 6F80498B D8F727DF 687CC37E 8FF3024F 30451A97 C4C81676
  C2FCA1A0 2B51D091 AA0B44E7 BA7FCA6A ED98CF5F 3EE60AD4 AB79DB09 BBE94F64
  C83FB22E 8936E561 C84AF542 DB4756E3 6EF31359 4210262A 43D2E1F7 15DD3E32
  15278156 9569D8BE 5EC38773 9A2EFB63 11C55FFD 93B4
  quit
username user privilege 15 secret 5 $1$wVlg$THSMUBnF3f3A3o2Oh18xS/
username ccadmin password 7 09774C051612111B180439
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key 01234567890123456789 address 96.252.99.66 no-xauth
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel
set peer OFFICEVPN IP
set transform-set ESP-3DES-SHA1
match address 103
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $FW_OUTSIDE$$ES_WAN$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dot11Radio0
no ip address
encryption mode ciphers tkip
ssid my_home
    authentication open
    authentication key-management wpa
    guest-mode
    wpa-psk ascii 7 133E1413181F0138273D15
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no dot11 extension aironet
bridge-group 1
bridge-group 1 spanning-disabled
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
bridge-group 1
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname verizonfios
ppp chap password 7 01050316521109012745411A
ppp pap sent-username verizonfios password 7 120F00051B11030A2C222B3B
interface BVI1
description $ES_LAN$$FW_INSIDE$
ip address 10.10.20.1 255.255.255.0
ip access-group 100 in
ip nat inside
ip tcp adjust-mss 1200
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
ip nat inside source static udp 10.10.20.20 88 interface Dialer0 88
ip nat inside source static tcp 10.10.20.20 3074 interface Dialer0 3074
ip nat inside source static udp 10.10.20.20 3074 interface Dialer0 3074
logging 10.10.20.27
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 1 permit 10.10.20.0 0.0.0.255
access-list 100 remark auto generated by Cisco SDM Express firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 103 remark SDM_ACL Category=4
access-list 103 remark IPSec Rule
access-list 103 permit ip 10.10.20.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 103 permit ip 10.10.20.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 110 deny   ip 10.10.20.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 110 deny   ip 10.10.20.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 110 permit ip 10.10.20.0 0.0.0.255 any
access-list 120 remark Xbox
access-list 120 permit tcp any eq 88 host 10.10.20.20 eq 88
access-list 120 permit tcp any eq 3074 host 10.10.20.20 eq 3074
access-list 120 permit udp any eq 3074 host 10.10.20.20 eq 3074
dialer-list 1 protocol ip permit
snmp-server community public RO
no cdp run
route-map SDM_RMAP_1 permit 1
match ip address 110
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
no modem enable
transport output telnet
line aux 0
line vty 0 4
privilege level 15
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
1 REPLY
Silver
see the option "client Isolation"in the Ap
Posted by WebUser Anshul Rohilla
451
