Wireless clients Roaming
Hi every body!
I´m implementing a wireless network an our client wants the works in this way.
One SSID on al building floors but Each floor with his own subnet
He wants to have roaming in al building floors.
The questions is. A client associated to an AP on floor "A" and it moving to a floor "B" cant it preserve the IP address af floor a and connect to an AP in the floor "B" (make a roaming), with out loss connection?
The APs are in controller mode and the version ins 7.0.116
Thanks in advance.
Hall of Fame Super Gold
Define inter-floor "roaming".  What client are you talking about?  How do you go from one floor to another?  Is there wireless signal in the elevator or in the stairwell?
Hi leolaohoo,
The clients are Lap-Top(s), Ipad, Smart Phones
The user wil goin from floor A to floor B using stairwell
Yes, we have APs over the stairwell to cover these area
The APs are all on H-REAP mode an we are using vlan mapping to match the vlan with the SSID on each floor.
The customer wants to have just one SSID and different subnets on each floor.
We have just only one controller.
best regards
Is there a real requirement to have each floor on its own subnet (specifically for the wireless network) ?  This question is pertinent because there is the potential to simplify roaming, maintaining connectivity, and preserving the same IP address - this is also known as L2 Roaming.
Essentially, you would perform the following:
  • Define an SSID for your access point(s)
  • Map the SSID to a VLAN
    • Clients are completely unaware/abstracted from the SSID being mapped to a VLAN
    • Allows multiple SSIDs to be broadcasted from the AP as long as each is mapped to a specific VLAN
  • Configure ethernet interface on AP for dot1q encapsulation
    • Enables multiple VLANs to traverse the link between the AP & Switch
  • Configure interface(s) connected to access point for dot1q encapsulation
  • Configure interface(s) between switches for dot1q encapsulation
  • Create VLAN (specified by step 2) on each switch (or use VTP)
  • Happy roaming
Roaming is always initiated by client; it will monitor the received signal strength and when it encounters another access point with the same SSID (different BSSID) with better signal, it will deassociate with the 1st SSID and associate with the second access point.  If your wireless environment is configured as indicated above, the client will maintain its IP address (along with all its bindings) will be preserved (applications will continue to work and are unaffected from roaming - seamless roaming.
However, if the business requirements stipulate true L3 roaming ,here is a link to a post made that has poses a similar inquiry.
Discussion:
https://supportforums.cisco.com/thread/334412
Documentation:
http://www.cisco.com/en/US/docs/wireless/controller/4.2/configuration/guide/c42mobil.html
Let me know if this helps!
Hi Mattehw, the stage you comment was the first optino, but our customer don´t like the idea of "many" SSID.
I read the linked document, but I have just only one controller, Is possible to use the Anchor feature with just one controller over one Mobility group?.
Thanks in advance.
The same SSID is mapped to each access point and from the client's perspective, they only see a single SSID broadcasted.
What specifically are the requirements from the customer?
For example, here is a wireless network that is spread across multiple locations that are using same SSID:
Command executed on Windows 7 machien: netsh wlan show networks mode=bssid
SSID 1 : blizzard
    Network type            : Infrastructure
    Authentication          : WPA2-Enterprise
    Encryption              : CCMP
    BSSID 1                 : 88:f0:77:ad:30:6f
         Signal             : 99%
         Radio type         : 802.11n
         Channel            : 149
         Basic rates (Mbps) : 12
         Other rates (Mbps) : 18 24 36 48 54
    BSSID 2                 : 88:f0:77:ad:59:6f
         Signal             : 45%
         Channel            : 153
    BSSID 3                 : 88:f0:77:f2:6e:5f
         Signal             : 45%
         Channel            : 36
    BSSID 4                 : 88:f0:77:f2:73:2f
However, the laptop only sees a single SSID despite multiple APs broadcasting :
In controlelr based deployments L3 roaming is possible where you can maintain the ip address of the wireless client
Hall of Fame Super Silver
Re: Wireless clients Roaming
You mentioned the APs are in h-reap. So hen a user roams from floor A to floor B and the SSID is mapped to
A differet vlan in each floor, roaming will break. If you want that to work, you need to either put the APs in local mode or centrally switch the WLAN. That would mean that each floor vlan would have to reside on the location the wlc is located. There is no other way to get that to work.
-Scott
2057
