Wireless connection speed
t-malensek
What makes clients connect at slower speeds when they have rssi beter than -65?
Scott Fella
Just to add... the AP's redio sensitivity also comes into play... It depends also on what the client and AP negotiates their modulation at.
for example a 3700:
http://www.cisco.com/c/en/us/products/collateral/wireless/3700-series-access-point/data_sheet_c78-729421.html
-91 dBm @ 6 Mbps
-91 dBm @ 9 Mbps
-91 dBm @ 12 Mbps
-90 dBm @ 18 Mbps
-87 dBm @ 24 Mbps
-85 dBm @ 36 Mbps
-80 dBm @ 48 Mbps
-79 dBm @ 54 Mbps
-Scott
Leo Laohoo
1. When you have low-speed data rates set to MANDATORY;
2. Wireless NIC makes the final decision what AP to join and what data rates to use.
