Wireless issue on some clients
Dear Community,
I have a problem with a WLC5508 that i've upgraded from 7.0.112.21 to 7.5.
Every thing was running fine for one 3 days, but now i have some issues with my main SSID.
the configuration of this SSID :
Radio Policy : All
Security Policies : [WPA+WPA2] [Auth(802.1X))
Authentication, no accounting
The problem : some of my clients are not able to connect anymore since they are not authenticated anymore. but some of them are still working (5% of client are working.
On my laptop, the authentication is working fine ON THE AP I WAS CONNECTED BEFORE THE ISSUE. if i try to roam, it doesn't work anymore. if i come back to the previous access point, i need to disconnect/connect to the WLAN and it works again...
Here are the logs (WebUI : Management > logs)
*Dot1x_NW_MsgTask_0: Nov 14 13:04:17.133: #DOT1X-3-INVALID_WPA_KEY_MSG_
STATE: 1x_eapkey.c:864 Received invalid EAPOL-key M2 msg in START  state - invalid secure bit; KeyLen 24, Key type 1, client 18:3d:a2:39:1c:10
*Dot1x_NW_MsgTask_0: Nov 14 13:04:16.003: #DOT1X-3-INVALID_WPA_KEY_MSG_
*Dot1x_NW_MsgTask_0: Nov 14 13:03:42.133: #DOT1X-3-INVALID_WPA_KEY_MSG_
STATE: 1x_eapkey.c:864 Received invalid EAPOL-key M2 msg in START  state - invalid secure bit; KeyLen 40, Key type 1, client 18:3d:a2:38:53:50
*Dot1x_NW_MsgTask_0: Nov 14 13:03:41.100: #DOT1X-3-INVALID_WPA_KEY_MSG_
*Dot1x_NW_MsgTask_0: Nov 14 13:02:54.933: #DOT1X-3-INVALID_WPA_KEY_MSG_
STATE: 1x_eapkey.c:864 Received invalid EAPOL-key M2 msg in START  state - invalid secure bit; KeyLen 40, Key type 1, client 18:3d:a2:2d:c3:68
*Dot1x_NW_MsgTask_0: Nov 14 13:02:53.752: #DOT1X-3-INVALID_WPA_KEY_MSG_
*apfMsConnTask_2: Nov 14 13:02:48.911: #APF-3-AID_UPDATE_FAILED: apf_80211.c:9699 Error updating Association ID for REAP AP Clientb8:62:1f:41:66:c0 - AID 1
*apfMsConnTask_2: Nov 14 13:02:48.911: #LWAPP-3-INVALID_AID2: spam_api.c:1373 Association identifier 1 for client 58:94:6b:00:72:74 is already in use by 60:67:20:b1:c3:2c
*Dot1x_NW_MsgTask_4: Nov 14 13:02:04.534: #DOT1X-3-INVALID_WPA_KEY_MSG_
STATE: 1x_eapkey.c:864 Received invalid EAPOL-key M2 msg in START  state - invalid secure bit; KeyLen 40, Key type 1, client 60:67:20:69:30:b4
*Dot1x_NW_MsgTask_4: Nov 14 13:02:03.512: #DOT1X-3-INVALID_WPA_KEY_MSG_
*apfMsConnTask_5: Nov 14 13:00:38.701: #APF-3-AID_UPDATE_FAILED: apf_80211.c:9699 Error updating Association ID for REAP AP Clientb8:62:1f:41:51:80 - AID 1
*apfMsConnTask_5: Nov 14 13:00:38.701: #LWAPP-3-INVALID_AID2: spam_api.c:1373 Association identifier 1 for client 60:67:20:b1:c1:54 is already in use by 60:67:20:69:31:2a
I'll send more debugging soon.
  • Getting Started with Wireless
Hall of Fame Super Silver
Re: Wireless issue on some clients
Post your show WLAN
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
VIP Purple
Client 18:3d:a2:39:1c:10
Resolution: Client authentication failed because of an authentication protocol error between the client and access point. Recommended Action    If the problem persists, try upgrading the client driver software or using different client software to isolate the cause
2.
Client 58:94:6b:00:72:74,60:67:20:b1:c3:2c,60:67:20:b1:c1:54,60:67:20:69:31:2a
Please check the DHCP scope range: May be there are more DHCP client then defined in DHCP scope.
Duplicate and invalid association identifier entries for FlexConnect clients.
or
your switch port configuration at the WLC. You have blocked vlans coming from the remote site. Remember that the APs will still need to reach the WLC even if you are running flexconnect.
3.
Client b8:62:1f:41:66:c0, b8:62:1f:41:51:80
Failed to update Association ID for REAP AP client.
Reagrds
Hi all!
And very thanks you for your prompt reply!
you'll see the sh wlan in the attached file.
Morever, i used the WLC Config analyser to check the configuration, on many AP's i got the following message :
60014,RF: AP has  channel utilization for 2.4 GHz radio higher than a threshold of 29%. Effect depends on RF conditions
Regarding the DHCP, i've allready check the servers, the scope is 5% used.
I've also check the switch configuration on WLC and on each AP's but every thing is ok.
One more information, on the same AP, some client works and some others dont work.
In the other attached file, you'll see the roaming of a client : At the beggining client is successfully connected, then it's limited access ... after the client comes back to the previous access point and it works fine.
I've update the drivers.
Best regards !
Hall of Fame Super Gold
Did you upgrade the FUS?
Yes the FUS was upgraded too, version 1.7.0
I've to say that i've upgraded the software+FUS last saturday (09/11) and that every thing was working fine for 5 days (Wednesday 13)
Best regards!
Hi, About:*apfMsConnTask_5:
About:
I think you hiting bug : CSCtn52995.
Should be repaired in 7.6.x
1146
