Community Member
Wireless LAN Solution for 120 Unit Apartment Complex
I'm in process of bidding on a project of setting up a  wireless LAN for an apartment complex. My dilemma is what's the best way  to implement it providing tenants as much speed as possible. Here's  what I have in mind:
1. Wireless Router which manages access to the ISP with WAPs working as repeaters
2.  A router which will manage access to the ISP then ran network cables to  each hallway with WAP and another WAP functioning as repeater
3. Should I go for something that has Guest login capability with either options
Also, I'd like to find a reliable hardware outside of the usual suspects like Netgear or Linksys.
Any suggestion and / or direction is greatly appreciated.
Hall of Fame Super Blue
Re: Wireless LAN Solution for 120 Unit Apartment Complex
Very commendable.
Not good.  You can't cable the AP up to a switch and then get a WLC?
What's your budget?
Community Member
The budget for this one is roughly $5000
329
