Wireless N Speeds?
brendand05
Hi I have a 1252 access point and have a questions about the connection speed.
I am running off POE which as i understand only has enough power for 1 of the antenna modules.
I have disabled the 5GHz module and am running only the 2.4GHz module.
When I connect to the AP from a Windows 7 laptop which is Wireless N compatible the laptop shows
Radio Type 802.11g and when I connect it shows speed as 54Mbps
Also the AP only lists data rates to 54Mbps. Shouldnt Wireless N support 150Mbps or 300Mbps?
Is there any special config to enable wireless N150/300?
Scott Fella
Well on the 2.4ghz you will only see a max of 144mbps. For 802.11n, you need to either use open authentication or wpa2/aes. You must also have WMM enabled. Those are the only requirements you need.
Sent from my iPhone
-Scott
10 Replies 10
Scott Fella
Sent from my iPhone
-Scott
Tkip is not supported for 802.11n.
-Scott
Scott Fella
Forgot to mention, only on the 5ghz will you be able to obtain a Mac of 300mbps. This is because you would configure 40mhz channel width. 2.4ghz only allows for the default of 20mhz.
-Scott
My POE (15.4W) only allows one Antenna to be enabled
Depends on what IOS you are running.  If you run the latest IOS you should be able to get two radio modules operational with 15.4w of PoE but with lower MCS rates.
No... The 2.4ghz radio supports b/g and N. The 5ghz radio supports a and N. these radios are backwards compatible so in case you have older clients, they can still connect. If you have an 802.11n client, they will be able to connect using N if you have set it up correctly. But you will only get up to 144 Mbps.
Sent from my iPhone
-Scott
Can a Wireless G client connect to the 5.0GHz A/N antenna?
No.  Only 2.4 Ghz.
No they can't. b/g is 2.4ghz only and a is 5ghz only. Like Leo mentioned, you still can connect the other radio (5ghz).
Sent from my iPhone
-Scott
You could maybe buy a power cord so that you can run both radios at full power. The part number is toward the bottom of the doc. Probably can find it cheap online.
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6973/ps8382/product_data_sheet0900aecd806b7c6d.html
Sent from my iPhone
-Scott
Here is the part: air-pwr-sply1
It's cheaper than getting a power injector.
-Scott
So sounds like 2.4GHz only is the way to go and leave 5.0GHz disabled.
Read my first post:  If you run the latest IOS you should be able to get two radio modules operational with 15.4w of PoE but with lower MCS rates.
Check this one out:
http://www.phihong.com/html/poe31x-1at_30w_single_port_midspan.html
