Wireless network not able to go to internet
Hello Everyone.
Got this topolgy:
WLC------AP-----wireless client
WLC:2106
AP: AIR-LAP1242AG
wireless client: laptop
The WLC can see the AP, and already setup a wireless LAN. This is working because from the wireless client I can access the GUI from the WLC (using the wireless connection). However I cannot "see" how to make that wireless lan connect to internet.
How does the WLC connects to internet?
The WLC does NAT?
Should I connect a switch to the WLC, then perform NAT on that switch to reach internet?
Can you describe me what to connect to the WLC so my simple topology reaches internet?
Thanks everyone for your time
Re: Wireless network not able to go to internet
The WLC does not route any traffic. Think of the WLC and APs as one big Accesspoint without routing - everything it does is take packets from the wireless and put them on wired (and vice versa).
So yes, connect the WLC to a switch and do the routing on the switch, your favorite router or anything you like. configure your WLAN in a specific VLAN via dynamic interfaces on the WLC, allow this VLAN on the uplink to the WLC and put your router into this VLAN.
Something easy you can do is plug a laptop into your vlan and work out your issues, if your laptop can get internet your wireless would as well..
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
171
