Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Wireless network out of range - Win XP
Hi all
I have some laptops at work with some wireless issues, I have some 1242AG access points with 2 ssid's broadcast, The issue is that some laptops can see both SSID's, but one of the SSID's is showing as out of range, but then I have another laptop which can see them both fine. Are we looking at a driver issue maybe on the laptop?
cheers
Carl
Re: Wireless network out of range - Win XP
I wouldn't trust the number of bars.. Did you try to connect on either of the laptops?
Yes and one of them connected fine, driver issue?
I would also see this as a driver problem.
I have AP 1252's and in a few offices, I have a Wi-Fi desktop that has an ideal signal with a laptop (roams around) that has a flaky connection and drops out. (Dell Latitude D620) after a driver update signal quality has improved.
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
731
