Wireless Questions
Hello
can someone assist with answers for my queries
  1. Recommended Tool for wireless site survey
  2. recommended document to place the AP on wall or ceiling
  3. what is the max bandwidth available on LAP ( comparision matrx for different LAP on bandwidth )
  4. Can 2.4 and 5.8 Ghz Antenna be installed on the same LAP
  5. Are upgrade/downgrade of AP doable from LAP to Standaone and vice-versa
config questions
  1. WLC and AP needs to be in the same vlan or different vlan
  2. can AP be assigned static IP or need dynamic IP
  3. Guest VLAN get IP from WLC DHCP service or need from Windows AD infrastructure
thanks
ST
Everyone's tags (2)
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Re: Wireless Questions
AirMagnet Survey Pro or Ekahau
This is your deliverable so it's up to you what you use.
All the newer 802.11N APs have gigabit Ethernet ports do you need to calculate what the required bandwidth per user is.
There are APs with builtin antennas, but if you use an ap with external, you need to make sure you use the correct antenna for each of the radios.
Yes
config questionsWLC and AP needs to be in the same vlan or different vlan
Either way
Either way
Either way
-Scott
Hall of Fame Super Gold
Wireless Questions
Airmagnet Site Survey or Ekahau.
According to George, Ekahau will soon be releasing an iPad version soon.
Depends on the model of your WAP.  An internal-antenna WAP can be mounted on a wall without any changes.   A WAP with an external antenna can be mounted on the wall but you need to make adjustments to your antenna or find a suitable antenna for wall mounting.  I mean, you don't want a "disco stick" and mount your antenna against a wall.  Instead you may consider looking at a patch antenna for wall mounting.
There are two models of WAPs.  One with a single radio (2.4 Ghz only) and dual radio.  With WAPs with external antenna, you can choose to purchase an antenna with a single pigtail, double pigtail, triple pigtail or quad pigtail.
Conversion from controller-based IOS to autonomous IOS is as easy as a press of a button.  The downside is this:  The WAP has to be there with you or you can't press the button.
If the WAP has joined to a controller, you can covert it down to autonomous by using a single CLI command.
Converting from autonomous IOS to controller-based IOS is simply using a single CLI command.
In production, the WAP is recommended to be in different VLANs.
Whatever floats your boat.  I'd prefer DHCP.
Yes
Either way
Either way
Either way
-Scott
Wireless Questions
Wireless Questions
Thank You  Scott + leolaohoo
Wireless Questions
Thanks for taking the time to rate our posts.
yes thank you for using the rating system
-Scott
368
