Wireless Radius server authentication issue
Hi All,
Below is he output from debug radius authentication from my AP.
I can see request is forwarding from AP to radius but Radius is not sending any response.Not sure why its not responding.
I also did not under stand few out outputs also
no sg in radius-timers and
RADIUS/DECODE: parse response no app start; FAIL
what does it mean.
I  restarted radius server , changed secret key but no luck.
019639: May  1 16:15:08.727: RADIUS:  User-Name           [1]   32  "host/3KYGRH1.idcap.intdata.com"
019640: May  1 16:15:08.727: RADIUS:  Framed-MTU          [12]  6   1400
019641: May  1 16:15:08.727: RADIUS:  Called-Station-Id   [30]  16  "0012.01d6.f691"
019642: May  1 16:15:08.727: RADIUS:  Calling-Station-Id  [31]  16  "0021.6aca.9bae"
019643: May  1 16:15:08.727: RADIUS:  Service-Type        [6]   6   Login                     [1]
019644: May  1 16:15:08.727: RADIUS:  Message-Authenticato[80]  18  *
019645: May  1 16:15:08.728: RADIUS:  EAP-Message         [79]  37
019646: May  1 16:15:08.728: RADIUS:   02 02 00 23 01 68 6F 73 74 2F 33 4B 59 47 52 48  [???#?host/3KYGRH]
019647: May  1 16:15:08.729: RADIUS:   31 2E 69 64 63 61 70 2E 69 6E 74 64 61 74 61 2E  [1.idcap.intdata.]
019648: May  1 16:15:08.729: RADIUS:   63 6F 6D                                         [com]
019649: May  1 16:15:08.729: RADIUS:  NAS-Port-Type       [61]  6   802.11 wireless           [19]
019650: May  1 16:15:08.729: RADIUS:  NAS-Port            [5]   6   63096
019651: May  1 16:15:08.729: RADIUS:  NAS-IP-Address      [4]   6   192.168.61.197
019652: May  1 16:15:08.729: RADIUS:  Nas-Identifier      [32]  18  "s-melmvn-aironet"
019653: May  1 16:15:13.932: RADIUS: no sg in radius-timers: ctx 0xD0A570 sg 0x0000
019654: May  1 16:15:13.932: RADIUS: Retransmit to (172.24.33.5:1645,1646) for id 1645/111
019655: May  1 16:15:19.561: RADIUS: no sg in radius-timers: ctx 0xD0A570 sg 0x0000
019656: May  1 16:15:19.561: RADIUS: Retransmit to (172.24.33.5:1645,1646) for id 1645/111
019657: May  1 16:15:25.191: RADIUS: no sg in radius-timers: ctx 0xD0A570 sg 0x0000
019658: May  1 16:15:25.191: RADIUS: Retransmit to (172.24.33.5:1645,1646) for id 1645/111
019659: May  1 16:15:30.661: RADIUS: no sg in radius-timers: ctx 0xD0A570 sg 0x0000
019660: May  1 16:15:30.661: RADIUS: No response from (172.24.33.5:1645,1646) for id 1645/111
019661: May  1 16:15:30.661: RADIUS/DECODE: parse response no app start; FAIL
019662: May  1 16:15:30.661: RADIUS/DECODE: parse response; FAIL
Second thing i am using
AIR-AP1231G-A-K9 and it does have only WPA support and laptops are supporting WPA2.
Does this can be also an issue?
Are you seeing anything in the radius server logs?
What type of radius server do you have ?
Did this work before?
Is this issue with only 1 ap ?
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Hi George,
Thanks for reply.
Can not see anything in logs.
Radius server is on window 2003. It never worked before. yes we have only 1 AP.
Hi Saurabh,
Check the connectivity between Server and AP.
Check is that server using 1812,1813 ports or 1645,1646 ports and configure AP to match it.
Kasun
Hall of Fame Super Silver
Re: Wireless Radius server authentication issue
Just to add my 2 cents, you have the SSID setup or wpa, but your clients are setup or wpa2? This will not work if that is how you have it setup. I'm also guessing you have defined the radius server on the AP and have added the ap as a AAA client on the radius server with the same shared secret? In your windows 7, you have the client setup for wpa-enterprise?
-Scott
1087
