Community Member
Wireless Stress & user density Test
Hi All,
I have a project coming up where I need to test and confirm the existing Wireless setup can be used for a high density (approx 50-60 users) in a big conference hall.
I still don't know the environment, but I will get in touch with the customer to know more about the building, a detailed existing WLAN setup and the purpose of the WLAN in this meeting.
I was wondering, is there a way that we can simulate the total number of users and test the application behaviour? I know we can use iperf/jperf to test the bandwidth, but I am not sure how can we simulate 50-60 users in a WLAN environment and show the per user bandwidth availability to the customer.
If the customer says, he needs a 5 MB per user bandwidth availability in the conference hall for all 50-60 users, how can we test it and show the results to the customer?
There are 2 APs currently in the conference hall and 2 more will be added. These are 1140 dual band APs, remotely managed by a WLC at different site.
Thanks and Regards,
CJ
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Wireless Stress & user density Test
We have used Veriwave to test density for various projects, but that tool isn't cheap.
You can always use the default calculations. Wireless is half duplex so you can say if users are all 802.11n, the max on the 2.4ghz would be 144mbps and half of that is the actual throughout for one device. You would divide that number (72) by the number of devices which will give you a theoretical throughout. Max on the 5ghz using 40 MHz channel is 300mbps and theoretical max for one user at 150mbps.
-Scott
-Scott
Community Member
Thanks for the clarification Scott
CJ
No problem.
-Scott
192
