Community Member
Wism 2 Upgrade to 7.4.110 can not work
I have a problem about WISM2 . After i upgraded Wism 2  version 7.2.110.0 to 7.4.110.0 It cannot work.
When Wism 2 is start up about 5 - 10 minute. It will reboot again.
WS-C6509-E Software Version is  12.2(33)SXJ3. It configure VSS . Supervisor Model  is VS-S720-10G
It show massage in log when Wism 2 is down as below.
Jan  8 14:47:09.113 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/4/2, changed state to down
Jan  8 14:47:09.133 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/4/2, changed state to up
Jan  8 14:48:37.521 GMT: %WiSM-5-STATE: Controller 1 in slot 36 is Oper-Down
Jan  8 14:48:51.141 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/4/2, changed state to down
Jan  8 14:48:51.153 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/4/2, changed state to up
Jan  8 14:49:35.562 GMT: %WiSM-5-STATE: Controller 1 in slot 36 is Oper-Up
How should i do to solve this problem ?
Termsak
Everyone's tags (1)
1 ACCEPTED SOLUTION
Community Member
Yes already.
Hall of Fame Super Gold
Did you upgrade the FUS of the WiSM-2?
Community Member
Yes already.
Yes already.
Telnet/SSH and post the output to the command "sh sysinfo".
Community Member
Wism 2 Version  7.2.110.0
I cannot access with SSH/Telnet. It reject.
But i can access with browser only.
On your 6500 do the following:  session switch X module Y controller 1
Then post the output to the command "sh sysinfo".
Community Member
When i use your command . It can not access . it reject same SSH.
But in version 7.4.110.0 . I can
Re: Wism 2 Upgrade to 7.4.110 can not work
Something is not right here.
Can you post the output to the 6500 command "sh wism switch X module Y controller 1 status". Please post the ENTIRE output.
Sent from Cisco Technical Support Wii App
Community Member
This is the result.
6509TG-E-VSS-1#sh wism switch 2 module 4 controller 1 status
WiSM Controller 1 in Slot 36 configured with auto-lag
Operational Status of the Controller : Oper-Up
Service VLAN                                : 192
Service Port                                   : 3
Service Port Mac Address               : 30e4.db39.2621
Service IP Address                          : 192.168.1.4
Management IP Address                 : 172.17.5.253
Software Version                            : 7.2.110.0
Port Channel Number                      : 727
Allowed-vlan list                              : 6,36,49-50,65,94,118-119
Native VLAN ID                               : 94
WCP Keep Alive Missed                  : 0
Community Member
I try to access Wism2 by CLI many time and I can access to Wism2
[Connection to 192.168.1.4 closed by foreign host]
6509TG-E-VSS-1#session switch 2 slot 4 processor 1
The default escape character is Ctrl-^, then x.
You can also type 'exit' at the remote prompt to end the session
Trying 192.168.1.4 ... Open
(WiSM-slot36-1)
User:
(WiSM-slot36-1)
User:
Password:
(WiSM-slot36-1) >
The result of sysinfo as below:
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.2.110.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 7.0.112.21
Firmware Version................................. FPGA 1.7, Env 0.0, USB console 2.2
Build Type....................................... DATA + WPS
System Name......................................
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1293
IP Address....................................... 172.17.5.253
Last Reset....................................... Software reset
System Up Time................................... 0 days 6 hrs 55 mins 53 secs
System Timezone Location......................... (GMT +7:00) Saigon, Hanoi, Bangkok, Jakatar
Configured Country............................... TH  - Thailand
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 4
Number of Active Clients......................... 4532
Burned-in MAC Address............................ 30:E4:DB:39:26:20
Maximum number of APs supported.................. 300
Before you upload the firmware, can you please check that the file's MD5 hash checksum is a match to the hash checksum value found in the Cisco website?
Community Member
358
