WiSM - Gigabit Ethernet 4/9 Down/Up
I have a WiSM installed in slot 4 of a 6509 chassis.  Every once in a while I see Gi 4/9 going down/up.  The logs indicate that it did so within the same second, so I'm wondering if it really ever went down at all.  'show wism status' all say oper-up, and I don't see any impact to users.  Knowing that the WiSM uses many physical connections to the backplane as one logical connection, I suspect what's going on could be physical or software related.  We're running 5.2.193.0 on them.
Scott
Everyone's tags (4)
1 REPLY
Re: WiSM - Gigabit Ethernet 4/9 Down/Up
Hey Scott,
What version of code are you running on the Sup? I had a similar issue and we updated the SUP and it went away ..It was over a year ago, so i dont recall  sup versions ...
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
363
