Community Member
WiSM redundancy/failover
Cisco documents mentions only up to tertiary WLC. The thing is each WiSM has 2 WLC 4404 cards. We have 2 WiSM modules. How do we configure the WiSM modules for redundancy/failover? -Thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: WiSM redundancy/failover
Yes... same mobility group... so in case you have roaming between the A and B wlc's you will be okay.
-Scott
If you have two WiSM's in one chassis then I would set it up like this... no need for a tertiary:
WiSM 1 WLC 1 A
WiSM 1 WLC 2 B
WiSM 2 WLC 1 A
WiSM 2 WLC 2 B
Just break up the sections via floor, building or sections.
ex.
A = floors 1-3
B = floors 4-6
-Scott
Community Member
With A & B being mobility group? -Thanks
-Scott
265
