WISM2 BUG OR NOT ?
Hi everyone,
I have a problem with our wism2
we have 2 6513 in VSS, and we have 2 wism modules in different 6513
i configured WISM2 with basic configs
when i use "show wism status" i see
Slot  Controller  Service IP       Management IP    SW Version    Controller Type    Status
26    1           0.0.0.0          0.0.0.0                       WS-SVC-WISM-2-K9   Service Port Up
42    1           0.0.0.0          0.0.0.0                       WS-SVC-WISM-2-K9   Service Port Up
IT DOESNT SHOW ME SERVICE AND MANAGEMENT IP ADDRESS, BUT IF I CONNECT TO WISM2 BY CONSOLE CABLE ALL IP I CONFIGURED FROM INSTALLATION WIZARD ARE THERE, is tha bug ? why he doest show me
my
service vlan 301
mgmt vlan 302
redundancy vlan 303
here my configs about wism
wism service-vlan 301
wism redundancy-vlan 303
wism switch 1 module 10 controller 1 allowed-vlan 302,303
wism switch 2 module 10 controller 1 allowed-vlan 302,303
wism switch 1 module 10 controller 1 native-vlan 302
wism switch 2 module 10 controller 1 native-vlan 302
wism switch 1 module 10 controller 1 qos trust dscp
wism switch 2 module 10 controller 1 qos trust dscp
my VLAN interfaces (SERVICE, MGMT, REDUNDANCY)
interface Vlan301
ip address 10.30.1.254 255.255.255.0
interface Vlan302
ip address 10.30.2.254 255.255.255.0
interface Vlan303
no ip address
My wism2 created PORT CHANNELS and 2 interface ( it is the same on my second WISM2)
Te1/10/1               unassigned      YES unset  up                    up
Te1/10/2               unassigned      YES unset  up                    up
GigabitEthernet1/10/3  unassigned      YES unset  up                    up
GigabitEthernet1/10/4  unassigned      YES unset  up                    up
My etherchannel summary
707    Po707(SU)        -        Te1/10/1(P)    Te1/10/2(P)
739    Po739(SU)        -        Te2/10/1(P)    Te2/10/2(P)
Please help
Everyone's tags (1)
Bronze
WISM2 BUG OR NOT ?
please remove the redundancy VLAN from the allowed VLANs
www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bd3504.shtml#vlan
then reboot.
WISM2 BUG OR NOT ?
Yahya,
No it doesnt help, again wism2s dont want to show me there service and management ip i configured via console
WISM2 BUG OR NOT ?
Any Suggestions ??
Hall of Fame Super Gold
Re: WISM2 BUG OR NOT ?
What IOS is your chassis?
Have you tried moving your WiSM2 to a different slot?  Preferrably in a slot ABOVE the Supervisor Card?
Leo,
show version
Cisco IOS Software, s2t54 Software (s2t54-ADVIPSERVICESK9-M), Version 15.1(1)SY1        , RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 01-May-13 12:43 by prod_rel_team
ROM: System Bootstrap, Version 12.2(50r)SYS3, RELEASE SOFTWARE (fc1)
CORE-VSS uptime is 12 minutes
Uptime for this control processor is 14 minutes
System returned to ROM by power on
System image file is "bootdisk:s2t54-advipservicesk9-mz.SPA.151-1.SY1.bin"
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6513-E (M8572) processor (revision ) with 1785856K/262144K bytes of memory.
Processor board ID FXS1727Q3H6
CPU: MPC8572_E, Version: 2.2, (0x80E80022)
CORE: E500, Version: 3.0, (0x80210030)
CPU:1500MHz, CCB:600MHz, DDR:600MHz
L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from power-on
61 Virtual Ethernet interfaces
208 Gigabit Ethernet interfaces
44 Ten Gigabit Ethernet interfaces
2543K bytes of non-volatile configuration memory.
WISM2 BUG OR NOT ?
Post the output:
sh wism switch 1 module 10 controller 1 status
sh wism switch 2 module 10 controller 1 status
CORE-VSS#show wism switch 1 module 10 controller 1 status
WiSM Controller 1 in Slot 26 configured with auto-lag
Operational Status of the Controller : Started KeepAlive
Service VLAN                         : 301
Service Port                         : 3
Service Port Mac Address             : 6c20.562c.3321
Service IP Address                   : 0.0.0.0
Management IP Address                : 0.0.0.0
Software Version                     :
Port Channel Number                  : 707
Allowed-vlan list                    : 302
Native VLAN ID                       : 302
WCP Keep Alive Missed                : 0
CORE-VSS#show wism switch 2 module 10 controller 1 status
WiSM Controller 1 in Slot 42 configured with auto-lag
Service VLAN                         : 301
Service Port                         : 3
Service Port Mac Address             : 6c20.562c.3541
Software Version                     :
Port Channel Number                  : 739
WISM2 BUG OR NOT ?
Is this the correct Native VLAN?  I think the Native VLAN should be different to the Management IP address.
I made by guide, it worked before, we just turned off VSS and 6513 cant show ip address and connect to wism2
if i connect with a console cable to wisms, everything is fine all ip are configured, maybe problem in service, cause 6513 doesnt show wism2s ip
WISM2 BUG OR NOT ?
Leo,
I configured with your guide, can you answer for this:
If we can yo use in allowed-vlan range our service and redundancy vlans,
if i need an layer 3 interface for redundancy vlan (interface of vlan without ip)
Leo,
I reconfigured it now it is fine, but my there is a problem with redundancy between my primary and secondary wism2(HA),
so i saw this
Redundancy Mode = SSO ENABLED
     Local State = MAINTENANCE
      Peer State = UNKNOWN - Communication Down
            Unit = Primary
         Unit ID = 6C:20:56:2C:33:20
Redundancy State = Non Redundant
    Mobility MAC = 6C:20:56:2C:33:20
Maintenance Mode = Enabled
Maintenance cause= Incompatible Software license
Redundancy Management IP Address................. 10.30.2.10
Peer Redundancy Management IP Address............ 10.30.2.20
Redundancy Port IP Address....................... 169.254.2.10
Peer Redundancy Port IP Address.................. 169.254.2.20
it says license are incompatible
here is licenses
License Store: Evaluation License Storage
StoreIndex:  0  Feature: base-ap-count                     Version: 1.0
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
            Evaluation total period:  8 weeks  4 days
            Evaluation period left:  8 weeks  4 days
        License Count: 500 / 0 (Active/In-use)
        License Priority: None
and on my HA WISM2
>show license summary
This is a Controller with HA-SKU license.
                                         The base ap count license has been inherited from the Primary Controller.
        Inherited Apcount = 100/0 (Active/InUse)
        Any base ap count license on HA-SKU controller is disregarded.
                                       The disregarded license information is as follows..
        License Store: Primary License Storage
StoreIndex:  0  Feature: base                              Version: 1.0
        License Type: Permanent
        License Count: Non-Counted
        License Priority: Medium
StoreIndex:  1  Feature: base-ap-count                     Version: 1.0
        License State: Active, In Use
        License Count: 100 /100 (Active/In-use)
--More-- or (q)uit
StoreIndex:  2  Feature: data_encryption                   Version: 1.0
        License State: Inactive
how can i fix that ?
WISM2 BUG OR NOT ?
Oh this should be easy enough.
Send an email to license@cisco.com and tell them you want to RE-HOST the license of one of your WLC.
Provide the following serial number:
1.  Primary WLC;
2.  Secondary WLC.
507
