WLAN 4402 for Radius Authentication
Hi Guys,
Please help me on how I can set-up my WLAN controller 4402 for Radius authentication, if you have links or procedures that you can share, that will be very much appreciated. :-)
Thanks in advance.
1 ACCEPTED SOLUTION
Re: WLAN 4402 for Radius Authentication
It depends if you are using Cisco ACS or Windows IAS. The controller config is the same but the RADIUS side is different.
Also what are you trying to configure, managemment users, PEAP etc via RADIUS
PEAP via ACS is here
http://www.cisco.com/en/US/partner/products/ps6366/products_configuration_example09186a00807917aa.shtml
PEAP via IAS is here
http://www.cisco.com/en/US/partner/products/ps6366/products_configuration_example09186a0080921f67.shtml
Hope that helps
Hope that helps
Thanks for the link, that would be a great help. :-)
327
