WLAN authentication methods
I have a couple of questions about methods that can be used to authenticate an end user trying to access a WLAN.
1) In the Web authentication method, is it possible for an end user to use its own certificate in order to be authenticated? If yes, does this mean a customized web page has to be used?
2) Is it possible to have multiple authentication methods available (such as Web, VPN, 802.1x) and allow the end user to choose only one of them for authentication?
All answers (and related documentation) are appreciated in advance.
Kind Regards,
Maria
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Re: WLAN authentication methods
Maria,
The certificate option under WebAuth allows you to change the original default Cisco certificate with a trusted CA certificate. When a user who's is associated to an said that requires Web Policy, he or she will get a certificate error page in which he or she has to accept the certificate before they get redirected to the WebAuth page. This is because on the user device, Cisco is not a trusted CA. Installing a 3rd party certificate allows users to bypass this the same way when you browse to a secure site. RapidSSL is hat I have used alot in the past. They issue a root ca certificate and not chained certificates. Even though 5.1 andnlater code supports chained certificates, it is much easier to jus obtain a root ca certifiate.
Just do a search on Cisco's site for 3rd party certificate.
-Scott
Here is the link.... hope this helps:
http://www.ciscosystems.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00806e367a.shtml
-Scott
Let me give this a shot....
WebAuth uses a login page to authenticate a user either by login or passthrough. For a certificate, you need to configure a layer 2 encryption method (EAP). But... with a EAP type encryption, a user can use it's own certificate, if you are using EAP-TLS and the certificate is part of your CA. WebAuth is usally used for guest access which requires a login or passthrough only. No encryption usually and the ssid is broadcasted. Internal wireless users will use a security method the organization requires, so to secure things, you would not want a secure ssid for internal on a subnet that you have a lower type of encryption or authentication method. If you want to use WebAuth, VPN, WEP, or 802.1x, then each should have its own ssid and subnet..... this way you can ACL traffic to secure your network. Don't mix and match... just my thought!
-Scott
Thank you Scott for your reply.
In the following document :
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008067489f.shtml#guide
it shows under Security->Web Auth an option to configure the Web Login Page and another one for Certificate. I was wondering what this Certificate option is supposed to be doing.
Kind Regards,
Maria
Maria,
-Scott
Thank you Scott. I really appreciate your help. I have no problem searching/reading around, but in this case I've been assigned a task quite beyond my knowledge and I have to do it fast (rings a bell?). Dummy tries to learn wireless in 24 hours :-)
-Scott
Thank you very much.
595
