Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Silver
WLAN Configuration
I"m attempting to create a new WLAN on the 5508 controller that will allow access to the corporate network. I'm using WPA + WPA2 layer 2 security with authentication via PSK. When I input the required information and select apply I receive the message: The following errors occurred while updating the WLAN: Error in setting Interface Name. I notice the interface/interface group drop down on the general tab reverts from the network I want to point the WLAN to back to management. Any ideas why?
I'm not sure if it makes a difference but I do have another WLAN that is pointing to the same corporate network but it uses 802.1X authentication.
Posted by WebUser Terence Pearson from Cisco Support Community App
Re: WLAN Configuration
Can you paste the screenshots of the SSIDs (psk and dot1x) and the interface details which you are trying to use.
What is the wlc code?
As per your query please refer to the link-
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/c60wlan.html
Hope this will help you.
989
