WLAN Logging Messages
Hello
we have problems with VoWLAN (connection remains, but you hear nothing).
So I wanted to ask what these messages mean in the LOG. Unfortunately, I found nothing useful on the Internet.
*RRM-CLNT-5_0: Oct 13 13:37:48.027: #RRM-3-RRM_LOGMSG: rrmClientProc.c:2954 RRM LOG: rrmClientProcessPacket:Failure to process RRM_PKT_QUERY: type 1
*RRM-CLNT-5_0: Oct 13 13:37:48.027: #LOG-3-Q_IND: rrmClientProc.c:2954 RRM LOG: rrmClientProcessPacket:Failure to process RRM_PKT_QUERY: type 1
*RRM-DCLNT-5_0: Oct 13 13:37:48.428: #RRM-3-RRM_LOGMSG: rrmTables.c:682 RRM LOG:  Could not retrieve  RRM Coverage Measurement DataKey BSSID:9c:4e:20:c8:da:20,Key SlotId:1
*RRM-DCLNT-5_0: Oct 13 13:37:47.580: #RRM-3-RRM_LOGMSG: rrmTables.c:629 RRM LOG:  Could not retrieve  RRM CCA Measurement DataKey BSSID:0c:d9:96:db:a3:00,Key SlotId:1
*RRM-DCLNT-5_0: Oct 13 13:37:47.578: #RRM-3-RRM_LOGMSG: rrmTables.c:522 RRM LOG:  Could not retrieve  RRM Noise Measurement Data Key BSSID:0c:d9:96:db:a3:00,Key SlotId:1
*RRM-DCLNT-5_0: Oct 13 13:37:47.577: #RRM-3-RRM_LOGMSG: rrmTables.c:575 RRM LOG:  Could not retrieve  RRM Foreign Measurement DataKey BSSID:0c:d9:96:db:a3:00,Key SlotId:1
*RRM-DCLNT-5_0: Oct 13 13:37:47.228: #RRM-3-RRM_LOGMSG: rrmTables.c:682 RRM LOG:  Could not retrieve  RRM Coverage Measurement DataKey BSSID:9c:4e:20:c8:ad:b0,Key SlotId:1
*RRM-DCLNT-5_0: Oct 13 13:37:47.227: #RRM-3-RRM_LOGMSG: rrmTables.c:682 RRM LOG:  Could not retrieve  RRM Coverage Measurement DataKey BSSID:9c:4e:20:c8:ad:b0,Key SlotId:1
Thanks for you Support
regards Alexander
VIP Purple
Hi Alex,What is the WLC code
Hi Alex,
What is the WLC code you running ?
Looks like a RRM related bug of the code you are in
Rasika
**** Pls rate all useful responses ****
Refer the 2 BUGs:Could not
Refer the 2 BUGs:
Could not retrieve RRM xxxxxx Measurement Data Key SlotId:0/1
CSCuc25956
Symptom:
Customer may see the following messages in the controller msglog
*RRM-DCLNT-5_0: May 01 17:58:09.858: #RRM-3-RRM_LOGMSG: rrmTables.c:629 RRM LOG: Could not retrieve RRM CCA Measurement DataKey BSSID:xx:xx:xx:xx:xx:xx,Key SlotId:1
*RRM-DCLNT-5_0: May 01 17:58:09.857: #RRM-3-RRM_LOGMSG: rrmTables.c:522 RRM LOG: Could not retrieve RRM Noise Measurement Data Key BSSID:xx:xx:xx:xx:xx:xx,Key SlotId:1
*RRM-DCLNT-5_0: May 01 17:58:09.856: #RRM-3-RRM_LOGMSG: rrmTables.c:575 RRM LOG: Could not retrieve RRM Foreign Measurement DataKey BSSID:xx:xx:xx:xx:xx:xx,Key SlotId:1
Conditions:
Controller running 7.4.100.0 with the following APs, but not limited to:
AP1250
AP1130
AP2602
Workaround:
None
RRM AP Neighbor list is not synced to HA Standby after switchover
CSCue17421
Symptom:
After an AP SSO failover to an HA backup WLC, clients are seen to be unable to
associate to an 802.1X enabled WLAN. Wireless sniff of the beacons for the BSSID
shows that the privacy bit is off.
Conditions:
This is seen after the group key rotates on the BSSID.
Workaround:
Reboot the AP.
Known Affected Releases:
(3)
8.0(50.40)
7.4(100.0)
7.4(1.31)
VIP Purple
Thanks Mohan for bug details
Thanks Mohan for bug details +5
Rasika
101
