WLAN not showing up
I create a WLAN on my 5508 WLC called "Guest-Printers"
I created a vlan for it on the downstream (trunked) switch, created an interface on the controller with the correct IP
Then I created the WLAN, associated it with the vlan/interface, set the SSID to broadcast. I made sure the WLAN was active, and set security to WPA2/PSK and enabled DHCP option 82.
However, the WLAN is not advertising the SSID, and it does not appear in the default AP-Group
Why isn't it showing up there? I tried to join it manually, but couldn't.
Not sure what the problem is, and I don't see anything in the logs
1 ACCEPTED SOLUTION
If the WLAN ID is 17 or
If the WLAN ID is 17 or higher, then you need to add it to an AP group for it to be broadcast.
HTH,
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
but I already have a guest
but I already have a guest vlan on id 221 and that is broadcasting (uses web authentication)
is that different somehow?
you are correct -I changed it
you are correct -I changed it to 2 and it worked
396
