WLC 2106 redundancy uplinks / LAG
Hi to all,
We've a WLC2106 connected to a Distribution switch composed by a stack and 6x APs dislocated on the Access switches.
All the APs are in H-REAP mode so the WLANs are mapped to the WLC's management interface instead of a dynamic one.
How can I add redundancy on the connection from the WLC to the Distribution switch since the WLC2106 doesn't support LAG/Channel (implemented on all the WLC4400/5500 installed until yet) nor AP-Manager secondary interfaces???
Many thanks
Saluti
Omar
Hall of Fame Super Gold
Re: WLC 2106 redundancy uplinks / LAG
Get another 2100 and configure primary/secondary controller to the LAP.
Hi Leolaohoo,
thnx but I want to been able to have a redundacy on network connections from the WLC to the Distribution switches and not having a WLC's redundancy...
based on your answer I suppose that no network connections redundancy are available on the 2100 models (channel, AP manager secondary interface,...) are available...
Omar
The 2100 does not support LAG (it said so in the Configuration Guide).
Getting a 2nd link is not full redundancy because this only addresses link failure and not hardware failure.
Yes, you're right it's not fully redundant, but if you have the possibility to connect two interfaces to a single Cat3750 Stack, you limit the Single Point of Failure on the WLC (its Power Supply)...if you haven't, well, then you have multiple Point fo Failure: WLC and the LAN switch to which it's connected
1286
