Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
WLC 2106 with directly connected Accesspoints
I've tried to connect and join 1131AG directly to WLC2106 but it doesn't work. I can't find any solution/description for this but this feature is offered for the 2100 series. At the moment I use a L3 switch where I have connected the AP and also WLC and all works well(different WLAN's).I have also configured an additional Port(4) on WLC to separate a guest vlan, also no problem. But how can I built a small wireless environment where the accesspoints directly connected to the WLC(without the need of a switch)?
regards,
Rocco
Re: WLC 2106 with directly connected Accesspoints
Have you connected it to one of the POE ports? If yes, can you enable the following debugs:
debug capwap events enable
debug capwap errors enable
If you are using lwapp code, please substitute capwap with lwapp in the above debugs. Your controller config would also help.
Nagendra
Hi Nagendra,
thanks for reply, I think I found a solution but it's really complicated. I've configured LWAPP settings via console but this is only possible if you have an ap which was never joined to a controller otherwise you must change default user/password first to setup LWAPP credentials via console. Afterwards I can connect the ap directly to the 2106 and it joins perfectly but I thought it was easier to deploy a small wireless environment if I have just a few accesspoints.
regards,
rocco
255
