WLC 2112 - APs disassociating
matt.millington
I've found some discussion on this, but nothing that's helped resolve so I'm hoping someone can help. We recently purchased a 2112 WLC, running version 6.0.199.4. I have everything running through a single port on the controller, which is connected to a trunk port on our 3750 stack. Our management VLAN is vlan 40, and AP is plugged into another port on the same switch which is an access port in vlan 40. APs appear in the controller ok, receive an IP address, but we aren't able to connect to any of the WLANs and periodically the APs will disassociate with the following messages:
0Thu Mar 22 09:47:51 2012AP 'AP003a.99eb.702d', MAC: b8:62:1f:45:95:b0 disassociated previously due to AP Reset. Uptime: 0 days, 00 h 35 m 52 s . Last reset reason: operator changed 11g mode
1Thu Mar 22 09:47:39 2012AP Disassociated. Base Radio MAC:b8:62:1f:45:95:b0
2Thu Mar 22 09:47:39 2012AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:b8:62:1f:45:95:b0 Cause=New Discovery
I'm not sure if that's related to why we can't connect to the WLANs or not...
Another wrinkle is that if we plug in the AP directly to one of the PoE ports on the controller, it all works perfectly. Any ideas? I'm guessing its something switch-related since the only difference is that we're not going through the switch when it works.
Thanks in advance,
Matt
27 Replies 27
Scott Fella
I would make sure you have enough power available on the switches and also check the logs on the switch.
Scott Fella
Sent from my iPhone
-Scott
Should be plenty of power. The AP is the only PoE device powered in to the switch, and its a 3750G PoE switch. Let me ask this: Could it be an issue that the AP connects at 1Gbps and the WLC at 100Mbps?
I don't see any errors or issues on the switch side. Could it be network slowness? I don't see any of that, but just trying to figure out what could be causing it. They are plugged into the same switch. Its part of a stack, but there are only 3 devices plugged in to this particular switch.
That shouldn't make a difference.  You might want to check to verify that the AP is drawing 15.4 and that it is negotiating at 1000 full.  Do you see anythning on the switch logs?  Is the ap's on the same switch or different?  Have you tried switching the patch cable and moving the ap to a different port?
-Scott
I have tried a different port, same result. I have also swapped out network cables, same result.
It is drawing 15.4W on both of the ports I tried, and always negotiates at 1000 full. AP and WLC are on the same 3750 in the stack.
I also see this in the WLC log in the web interface:
AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:b8:62:1f:45:95:b0 Cause=Heartbeat Timeout
Anything in particular that I should be looking at in the switch logs?
Typically a heartbeat timeout means it's losing the connection to the controller (ie: capwap tunnel goes down); but that doesn't make any sense if they are on the same switch..
How long does the AP stay on-line before rebooting or is it random?
Weird that the WLC and AP are in the same switch stack and you are getting these errors.  Just look at the logs to see if the port shut down, etc.  Do the AP's in the same switch as the WLC fail also or just ap's that are on a different switch on the same stack?
-Scott
Both APs in the same switch and in different switches do the same thing. They don't reboot, just disassociate. Here is the status on one of them:
UP time: 2 hours+
Controller Associated Time: 6 minutes
Controller Association Latency: 14 seconds
They associate as soon as they come up, but then disassociate and reassociate. They have this message:
in addition to sometimes showing a Heartbeat Timeout cause for the disassociation. In addition, sometimes it shows the cause being Max Retransmissions. I thought it was just the AP, but it happens with the second AP as well. Here are my switch port configs:
For AP:
interface GigabitEthernet7/0/14
description Test AP
switchport access vlan 40
switchport mode access
spanning-tree portfast
For WLC:
interface GigabitEthernet7/0/2
description WLC Management Port
switchport trunk allowed vlan 40,55,82,94
switchport mode trunk
spanning-tree portfast trunk
It is detecting Rogue APs (these are the existing APs that we want to replace with this system). Could that be causing issues? I don't think so since it works just fine when plugged directly in to the WLC.
Could it be WLC software version?
In addition, I get this error:
AP 'AP003a.99eb.7167', MAC: b8:62:1f:45:bf:e0 disassociated previously due to AP Reset. Uptime: 0 days, 02 h 17 m 33 s . Last reset reason: operator changed 11g mode
Not sure what that means that the operator changed 11g mode...
Can you post the output from the console on one of the AP's?  If this is a new install? you don't have any AP's on this right now correct?  YOu should upgrad that WLC to 7.0.230.0.... musch beteer code if you ask me.
-Scott
Take a look at the counters on a port, and check if you are seeing large amounts of broadcast traffic.  The other thing to check is spanning-tree.  make sure that VLAN 40 is not reconverging often.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
We are in the process of getting our contract approved on cisco.com so we can have access to download the new code. Hopefully, that will do it. Here is what I get at the console of the AP:
*Mar 22 15:57:48.038: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar 22 15:58:01.060: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Mar 22 15:58:01.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.83.0.67 peer_port: 5246
*Mar 22 15:58:04.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Mar 22 15:58:41.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2015 Max retransmission count reached!
*Mar 22 15:58:41.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 10.83.0.67 is reached.
*Mar 22 15:59:00.999: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.83.0.67:5246
*Mar 22 15:59:04.037: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar 22 15:59:23.058: %CAPWAP-3-ERRORLOG: Go join a capwap controller
Also these:
*Mar 22 16:02:06.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.83.0.67 peer_port: 5246
*Mar 22 16:02:08.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Mar 22 16:02:11.018: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.83.0.67 peer_port: 5246
*Mar 22 16:02:11.019: %CAPWAP-5-SENDJOIN: sending Join Request to 10.83.0.67
*Mar 22 16:02:11.019: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Mar 22 16:02:11.100: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Mar 22 16:02:11.384: %CAPWAP-5-CHANGED: CAPWAP changed state to UP
*Mar 22 16:02:11.406: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Mar 22 16:02:12.406: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar 22 16:02:14.385: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller Cisco_Annex1
*Mar 22 16:02:14.424: %LWAPP-3-CLIENTEVENTLOG: SSID vcannex added to the slot[0]
*Mar 22 16:02:14.426: %LWAPP-3-CLIENTEVENTLOG: SSID vlan55 added to the slot[0]
*Mar 22 16:02:14.427: %LWAPP-3-CLIENTEVENTLOG: SSID vcannex added to the slot[1]
*Mar 22 16:02:14.429: %LWAPP-3-CLIENTEVENTLOG: SSID vlan55 added to the slot[1]
*Mar 22 16:02:14.439: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
Okay... is your management and ap mangers on the same vlan?  YOur AP's are on vlan 40, what about your management and ap-manager?
-Scott
Yes, they are all in VLAN 40, 10.83.0.64/26 is the network.
10.83.0.65 - gateway
10.83.0.66 - management
10.83.0.67 - ap-manager
.68-126 - DHCP pool for APs
