Community Member
WLC 2112 GUI Connection problem
I am not able to connect to the GUI on the Cisco Wireless Controller 2112.  I noticed from the interface summary that the "GU" (GUI?) are all "No" on both the management and ap-manager interfaces.  How to set them to "Yes" from the console (CLI)?
Thanks.
<<<<System Info>>>>
(Cisco Controller) >show interface summary
Interface Name         Port Vlan Id  IP Address       Type     Ap Mgr Gu
est
ap-manager         1     untagged 10.1.4.62  Static  Yes     No
management         1     untagged 10.1.4.61  Static  No      No
virtual        N/A  N/A       1.1.1.1      Static  No      No
(Cisco Controller) > show network summary
RF-Network Name............................. RFGroup
Web Mode.................................... Enable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Enable
Secure Shell (ssh).......................... Enable
Telnet...................................... Enable
Ethernet Multicast Mode..................... Disable
Ethernet Broadcast Mode..................... Disable
AP Multicast Mode........................... Multicast   Address : 0.0.0.0
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Disable
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Enable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
--More-- or (q)uit
Over The Air Provisioning of AP's........... Disable
AP Fallback ................................ Enable
Web Auth Redirect Ports .................... 80
Fast SSID Change ........................... Disabled
(Cisco Controller) > show run-config
Interface Configuration
Interface Name................................... ap-manager
MAC Address...................................... 70:81:05:af:1d:20
IP Address....................................... 10.1.4.62
IP Netmask....................................... 255.255.252.0
IP Gateway....................................... 10.1.2.1
VLAN............................................. untagged
Physical Port.................................... 1
Primary DHCP Server.............................. 10.1.2.1
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
Interface Name................................... management
IP Address....................................... 10.1.4.61
Quarantine-vlan.................................. 0
AP Manager....................................... No
Interface Name................................... virtual
IP Address....................................... 1.1.1.1
Virtual DNS Host Name............................ Disabled
Everyone's tags (3)
Re: WLC 2112 GUI Connection problem
Are you ragging the native clan on the switch?
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Community Member
Only set the port to trunk mode on the switch (Cisco 3560G).  No vlan.
Ok so is that IP in VLAN 1?
Steve
Community Member
Yes.  Only one vlan on the LAN, vlan 1.
The address you have configured for the management interface is not in the same subnet as the gateway you configured. If you correct the address you Gould be able to access it.
Steve
Community Member
The subnet mask is 255.255.252.0, they should be in the same subnet.
I can ping the DHCP server from the WLC:
(Cisco Controller) >ping 1 0.1.2.1
Send count=3, Receive count=3 from 10.1.2.1
From the server I can ping the WLC too:
Pinging 10.1.4.161 with 32 bytes of data:
Reply from 10.1.4.61: bytes=32 time=1ms TTL=64
Reply from 10.1.4.61: bytes=32 time<1ms TTL=64
Ping statistics for 10.1.4.61:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 1ms, Average = 0ms
I just couldn't access the WLC GUI through web browser.
That mask gives you from 10.1.0.0 to 10.1.3.255 and the WLC is 10.1.4.x as to why you can ping not sure
Steve
Community Member
I reset the WLC and did the initial setup.  The following are the new config, basically they are the same as provious, except the IP assignments.  Still can't access the GUI.  The GUI in the "Interface Information" are "No".
I still can ping the server from the WLC, and vice vesa.
est
ap-manager                       1    untagged 10.1.2.222  Static  Yes    No
management                       1    untagged 10.1.2.221  Static  No     No
(Cisco Controller) >show run-config
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 5.2.193.0
RTOS Version..................................... 5.2.193.0
Bootloader Version............................... 4.0.191.0
Emergency Image Version.......................... Error
Build Type....................................... DATA + WPS
System Name...................................... Cisco_af:1d:20
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.828
IP Address....................................... 10.1.2.221
System Up Time................................... 0 days 0 hrs 1 mins 33 secs
System Timezone Location.........................
Current Boot License Level.......................
Next Boot License Level..........................
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
--More-- or (q)uit
Internal Temperature............................. +78 C
Network Information
Telnet...................................... Disable
Mgmt Via Dynamic Interface.................. Disable
--More-- or (q)uit
Port Summary
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE
1  Normal  Forw Enable  Auto       100 Full   Up     Enable  N/A
2  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
3  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
4  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
5  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
6  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
7  Normal  Forw Enable  Auto       100 Full   Up     Enable  Enable  (Power On )
8  Normal  Disa Enable  Auto       Auto       Down   Enable  Enable  (Power Off)
IP Address....................................... 10.1.2.222
(Cisco Controller) >ping 10.1.2.1
C:\Users\Administrator>ping 10.1.2.221
Pinging 10.1.2.221 with 32 bytes of data:
Reply from 10.1.2.221: bytes=32 time=1ms TTL=64
Reply from 10.1.2.221: bytes=32 time<1ms TTL=64
Ping statistics for 10.1.2.221:
The No has to do with Guest interface.
Are you trying https? That is all the WLC supports by default and it doesn't redirect.
Steve
Community Member
Tried both http and https, none works.
Are you connected to port seven trying to access the WLC?
Steve
Community Member
No, An AP (Cisco Aironet 1141) is connected to the WLC, on port 7.  Port 1 is connected to the switch.
Can you share the switch config?
Steve
Community Member
WLC is on Port 30.
1528
