04-12-2017 01:56 AM - edited 07-05-2021 06:51 AM
Hello
I have problem about WLC 2500 time , when got force shutdown the time will back to factory(only the time).
I have set on CLI and make save also no solve
I have set on GUI and make save also not solve
I also set NTP still not solve
04-12-2017 02:09 AM
Post the complete output to the command "sh time".
04-12-2017 02:20 AM
04-12-2017 02:49 AM
That is odd. The output shows NTP is synchronized to a time source.
What is the exact version of the firmware the controller is running on?
04-12-2017 05:44 PM
Hi Leo
The firmware is 8.3.102.0
I also don't know what exactly the issue..
04-15-2017 05:43 AM
Can you upgrade to 8.3.112.0 and see if it improves things?
I had a 2500 controller running 8.3.102.0 code and I don't see this issue happening.
04-17-2017 11:51 PM
The 2500 uses a battery to store the time while it is shutdown and it has a lifetime .
This had been seen at multiple customers , one i can remember is in Australia .
RMA is the only option.if you cannot support NTP .
Upgrade will NOT work
The customer who had this issue didn't have a NTP and the WLC was powered up once in 6 months and AP was not joining because of time difference.
04-12-2017 03:39 AM
hi
1. Please do not post general WLC issues to this forum, it is for WLCCA application, moving the post
2. if you power cycle WLC and it loses the time, it means the battery is probably expired.
with NTP it should recover correct time, after boot
04-12-2017 05:42 PM
Hi Javier
Actually I don't know what forum I need to move and don't know how to move.
For WLC I don't think battery issue , cause I got 3 WLC new, all this 3 got same issue.
