07-30-2013 09:24 PM - edited 07-04-2021 12:33 AM
In past, WLC 2504 ran on software version 7.0.116 is working fine but it has an issue with WIN8.
I found that the issue solved by upgrade to version 7.4 and now I upgrade the controller already.
After upgrade I receiving many case about the access points are randomly shutdown anytime everyday. It means disappear on the dashboard.
I am trying to search a message for cause but not see.
Anyone see this issue and how to solve this.
Thanks in advance.
07-30-2013 11:02 PM
Hi Ratchapas,
Can you please tell me the access point type and number ???
I will recommand to use 7.3 version for 2504 WLC.
07-30-2013 11:30 PM
There were certain known bugs in 7.4.x.x affected certain AP models. If you are using 1142 this may be the bug you are hitting CSCud97983
Anyway it most likley to be a bug.. so check with cisco TAC & get a release which will fix those.
07-31-2013 01:59 PM
As per your query i can suggest you the following solution-
This can be a probable bug. Do need to contact TAC.
Hope this will help you.
08-01-2013 03:25 AM
I read in release note of version 7.4.100.60 it solved the issue but anyone try this?
Does New version have bugs?
08-01-2013 03:33 AM
Don't worry about 7.4.100.60. Upgrade to 7.5.102.0 instead.
Release Notes for Cisco Wireless LAN Controllers and Lightweight Access Points for Release 7.5.102.0
08-01-2013 03:44 AM
The one thing to understand is that you would probably of been better off upgrading to the latest v7.0.x to solve your issues. That is the most stable version for v7.x. Moving to v7.2.x, v7.3.x, v7.4.c and v7.5.x is just for features needed or ap support. v7.0.x is the only MD release and all the other trains will never be MD:). Just keep that in mind.
08-01-2013 08:18 AM
Dear Scott
I have some questions here.. I read about win 8 and the bug CSCua29504
The solution as say Ratchapas consist in upgrade the WLC. But I remember you wrote we can use TKIP for WPA Auth. and it works fine... I'm correct?
08-01-2013 10:37 PM
Hi Daniel,
TKIP for WPA auth is working fine.
In tomorrow, I will upgrade to 7.5.102.0 and will share the result.
Normally, what is a recommend while upgrading on the wireless controller? (such as disconnect all of access point or can upgrade the wireless controller while access points are associating)
08-01-2013 11:00 PM
Push the new firmware to the WLC and then invoke Pre-Image download to all the AP.
One the Pre-Image download is complete, reboot the controller.
08-04-2013 08:28 PM
Hi Leo Laohoo,
Invoke pre-image download to AP, What do you mean?
I will download th the new image to WLC after finish it shows save and restart to take effect, right?
I will restart while the AP is online, can I do?
For today I have plan to upgrade to 7.4.110.0
08-04-2013 08:48 PM
What Leo means is that you can download the code to the aps while they are still on and servicing clients.. Lessens downtime .. Read this
http://www.my80211.com/home/2011/2/20/wlc-predownload-the-image-to-the-access-points-from-the-cont.html
08-02-2013 09:10 AM
7.5 is not intended for bug fix... if you need bug fix then get 7.4.110.0 which posted today.
08-04-2013 09:37 PM
I will deploy 7.4.110 in a half.
08-19-2013 12:48 AM
Update
Let's update to 7.4.110, it is fine
