WLC 2504 Connectivity Problems
This is a tricky one.
I installed a 2504 WLC with three AP's. Two SSID’s were configured, one with WPA2/AES-TIKIP and the other with Web Auth.
After installation, customers could connect to WLAN without problem and .
The problem that is occurring is that since the beginning of week, customers PDA's, cell phones and iPad and cannot access Internet with any of the two WLAN but clients who used laptop have no connection problems. Also the DHCP Server is assigning IP's correctly.
This problem also occurs with test SSID I created which is Open Auth. I see associated Cell phones and IPAD to the WLC but none of these answers ping from the WLC.
This is a WLC 2504 with IOS 7.4.100.
  • Getting Started with Wireless
VIP Purple
HI Adrian,
1. Dont use WPA2-AES/TKIP on a WLAN, please use either wpa2-aes or wpa-tkip.
2.If still facing problem then please paste the output of this command for one mobile device: debug client
Hope it helps.
This would affect even the WLAN that is using Open Auth?
VIP Purple
Connect any mobile device whcih is not working and post the output of debug client .
This is what i get when i tried to connect a Cell phone to de WLAN:
*spamApTask7: Nov 13 13:46:09.181: 10:d5:42:8a:c5:20 Received Idle-Timeout from        AP ec:e1:a9:8f:02:10, slot 0 for STA 10:d5:42:8a:c5:20
*spamApTask7: Nov 13 13:46:09.182: 10:d5:42:8a:c5:20 apfMsDeleteByMscb Schedulin        g mobile for deletion with deleteReason 4, reasonCode 4
*spamApTask7: Nov 13 13:46:09.182: 10:d5:42:8a:c5:20 Scheduling deletion of Mobi        le Station:  (callerId: 30) in 1 seconds
*osapiBsnTimer: Nov 13 13:46:10.091: 10:d5:42:8a:c5:20 apfMsExpireCallback (apf_        ms.c:614) Expiring Mobile!
*apfReceiveTask: Nov 13 13:46:10.091: 10:d5:42:8a:c5:20 apfMsExpireMobileStation        (apf_ms.c:5803) Changing state for mobile 10:d5:42:8a:c5:20 on AP ec:e1:a9:8f:0        2:10 from Associated to Disassociated
*apfReceiveTask: Nov 13 13:46:10.091: 10:d5:42:8a:c5:20 Sent Deauthenticate to m        obile on BSSID ec:e1:a9:8f:02:10 slot 0(caller apf_ms.c:5897)
*apfReceiveTask: Nov 13 13:46:10.091: 10:d5:42:8a:c5:20 apfMsAssoStateDec
*apfReceiveTask: Nov 13 13:46:10.091: 10:d5:42:8a:c5:20 apfMsExpireMobileStation        (apf_ms.c:5935) Changing state for mobile 10:d5:42:8a:c5:20 on AP ec:e1:a9:8f:0        2:10 from Disassociated to Idle
*apfReceiveTask: Nov 13 13:46:10.091: 10:d5:42:8a:c5:20 pemApfDeleteMobileStatio        n2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfReceiveTask: Nov 13 13:46:10.091: 10:d5:42:8a:c5:20 192.168.8.123 RUN (20) D        eleted mobile LWAPP rule on AP [ec:e1:a9:8f:02:10]
*apfReceiveTask: Nov 13 13:46:10.091: 10:d5:42:8a:c5:20 apfMsRunStateDec
*apfReceiveTask: Nov 13 13:46:10.091: 10:d5:42:8a:c5:20 Deleting mobile on AP ec        :e1:a9:8f:02:10(0)
*pemReceiveTask: Nov 13 13:46:10.093: 10:d5:42:8a:c5:20 192.168.8.123 Removed NP
And several messages like this:
*apfMsConnTask_3: Nov 13 13:40:04.667: Stats update: Non Zero value
Re: WLC 2504 Connectivity Problems
Is this a normal situation?
DNS Server details:
      DNS server IP ............................. 0.0.0.0
  IP Address....................................... 192.168.8.123
Gateway Address.................................. Unknown
Netmask.......................................... Unknown
Policy Manager State............................. RUN
When apply the comm SHOW CLIENT DETAIL this is the output that I get from a client who is working fine and also a client who has the connectivity problem.
In this thread happens something similar but in the output is appears this response:
The client is being put on vlan 203
VLAN............................................. 203
Quarantine VLAN.................................. 0
Access VLAN...................................... 203
DNS the client is obtainging
DNS Server details:
      DNS server IP ............................. 75.75.75.75
      DNS server IP ............................. 75.75.76.76
Client IP Address
IP Address....................................... 10.1.21.149
Gateway Address.................................. 10.1.21.1
Netmask.......................................... 255.255.255.0
https://supportforums.cisco.com/thread/2219685
I just upgrade the WLC from 7.4.100 to 7.4.110 but nothing changed. The AP's are 1600I.
El mensaje fue editado por: Adrian Thames Esquivel
VIP Purple
HI Adrian,
*spamApTask7: Nov 13 13:46:09.182: 10:d5:42:8a:c5:20 apfMsDeleteByMscb Scheduling mobile for deletion with deleteReason 4, reasonCode 4
This error shows that Idle-Timeout timer expires! this happens when the AP stops hearing from the station(Mobile) for a specific time (300 seconds = 5 minutes by default. value is configurable under Controller->General).
If the AP/WLC does not receive any packets from the client, after a certain period of time, the client entry will be deleted.
The user idle timeout can be configured from 15~100000 seconds.
More about your error: https://supportforums.cisco.com/thread/2146151
Hope it helps.
Hi Sandeep,
This might be true, still what if this happens the moment a mobile phone tries to connect?
Adrian, you mentioned "customers PDA's, cell phones and iPad and cannot access Internet with any of the two WLAN" ; do you at least receive an IP address to a cell phone?
Also did you update your security policy with WPA2&AES or WPA&TKIP? There is an entire discussion here, of which we can summarize this:
  • AES is REQUIRED for 802.11n speeds. This is because the encryption is performed in hardware (TKIP is performed in software and hence doesn't support 802.11n).
  • WPA2 supports AES and optionally TKIP.
  • In some way, TKIP is a more complex version of WEP! It is based on the RC4 algorith buts uses much stronger keying material and offers additional security features (i.e. anti-replay).
  • AES is considered more secure than TKIP (RC4).
  • You 'can' run AES with WPA 'if' both the client and AP support it.
  • You 'can' run TKIP with WPA2 'if' both the client and AP support it.
  • Whats the difference between WPA and WPA2? WPA has a WPA-IE (Information Element) included with management frames. WPA2 has a RSN-IE included with management frames. The structure and contents of these IEs are DIFFERENT. This is why a WPA-AES client cannot associates with a WPA2-AES AP - because the IE are different.
  • The purpose of a WPA IE is generally the same as an RSN IE, but a few fields are changed or omitted.
  • WPA2 RSN-IE support things like PMKID to support fast roaming (WPA-IE don't).
  • Whats the difference between WPA-AES and WPA2-AES? As per the above, the main difference is the presence of different IEs. WPA2-AES devices support fast roaming, whereas WPA-AES devices wouldn't (the WPA-IE doesn't provide PMKID that are used for fast roaming).
  • It could be argued that there is only a slight security enhancement from WPA-AES and WPA2-AES. The encryption is the same, however there are additional fields such as the PMKID to support fast roaming. In addition, AES support is limited with WPA but commonplace with WPA2.
Hall of Fame Super Silver
Post your show WLAN
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
Hello everyone!
Today I did a test with my Cell phone Samsung Note 2 and I have the same conectivity problem.
I have installed the APK ipconfig from the Play Store for Android in my cell phone and y see that I getting IP Address, Mask and Gateway.
This is what I´ve got from the APK:
IP ADDRESS 192.168.8.181
MASK: 255.255.255.0
GATEWAY: 192.168.8.2
DHCP SERVER: 192.168.8.16
DNS1: 192.168.6.16
DNS2: 192.168.2.16
I have connected my laptop to the WLAN with no issue and I´m getting this:
Imagen integrada 2
The IP address of the DHCP Server is 192.168.8.16 and 192.168.6.16 and is a Microsoft Server.
I´ve created a test WLAN with OPEN AUTH but the problem remains.
Here is the OUTPUT you requested:
show wlan 1
WLAN Identifier.................................. 1
Profile Name..................................... APS-PT-01
Network Name (SSID).............................. APS-PT-01
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 16
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ 300 seconds
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... APS-Admin-WLC-01
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream          Downstream
Average Data Rate................................   0                      0
Average Realtime Data Rate.......................   0                      0
Burst Data Rate..................................   0                      0
Burst Realtime Data Rate.........................   0                      0
Per-Client Rate Limits........................... Upstream          Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Enabled
      WPA2 (RSN IE).............................. Enabled
      Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
(Cisco Controller) >
(Cisco Controller) >show w?
wgb            wlan           wps
(Cisco Controller) >show wlan 2
WLAN Identifier.................................. 2
Profile Name..................................... APS-Visitas-PT
Network Name (SSID).............................. APS-Visitas-PT
Radius Servers
Security
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   Web Based Authentication...................... Enabled
IPv4 ACL........................................ Unconfigured
IPv6 ACL........................................ Unconfigured
Web-Auth Flex ACL............................... Unconfigured
Web Authentication server precedence:
1............................................... local
2............................................... radius
3............................................... ldap
   Client MFP.................................... Optional but inactive (WPA2 not configured)
SIP CAC Fail Send-486-Busy Policy................ Disabled
(Cisco Controller) >show wlan 3
WLAN Identifier.................................. 3
Profile Name..................................... Prueba
Network Name (SSID).............................. Prueba
Number of Active Clients......................... 0
WMM UAPSD Compliant Client Support............... Enabled
CCX - AironetIe Support.......................... Disabled
Radius Servers
Security
   FT Support.................................... Enabled
   Client MFP.................................... Disabled
3683
