Community Member
WLC 2504 Web reauthentication issues
We recently facing web reauthentication issue with cisco 2504 wireless controller. While a user going out of wireless network and coming back he have to authenticate again.We tried all the session timeouts settings in the controller but still the problem persist.
Is any way to keep the webauthentication session ?
Hall of Fame Super Gold
Duplicate posts.   Go here:
Duplicate posts.
Go here:  http://supportforums.cisco.com/discussion/12191801/wlc-2504-web-reauthentication-issues
Since you are saying , you
Since you are saying , you have already played with timeout settings, I would recommend you to upgrade the code.
Hall of Fame Super Silver
That is how the WebAuth
That is how the WebAuth functions.  What you need to do is either use sleeping clients if your on v7.6 or else you need to increase the idle timeout.  This can be done on either the global setting on the main GUI page of the WLC or on the WLAN advanced tab, on new code.  The session timer has to be higher or disabled, than the idle timer.  I usually set the idle timer to 7200 or 14400 seconds (2 or 4 hours).  This give someone time to go to lunch and come back.  IF your running v7.6, then use the sleeping client feature.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-5/config_guide/b_cg75/b_cg75_chapter_010111.html
Please rate helpful post and Cisco Support Community will donate to Kiva
Scotty
-Scott
Please upgrade to the latest
Please upgrade to the latest version of WLC 2504 controller.
234
