WLC 2504 with AP 3502
Hello all, i need your help, i have a WLC but AP's not joined with controller,  this errors sends:
cisco AIR-CAP3602I-N-K9    (PowerPC) processor (revision A0) with 167926K/81920K bytes of memory.
Processor board ID FTX1734GJ9E
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.3.1.53
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 7C:69:F6:1A:2A:C4
Part Number                          : 73-14521-02
PCA Assembly Number                  : 800-37501-02
PCA Revision Number                  : A0
PCB Serial Number                    : FOC17306LVB
Top Assembly Part Number             : 800-35852-02
Top Assembly Serial Number           : FTX1734GJ9E
Top Revision Number                  : C0
Product/Model Number                 : AIR-CAP3602I-N-K9
% Please define a domain-name first.
*Aug  1 18:34:32.035: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Aug  1 18:34:32.035: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'WLAN_EstrellaR'running version 7.0.220.0 is rejected.
*Aug  1 18:34:32.035: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Aug  1 18:34:32.035: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Aug  1 18:34:32.035: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Aug  1 18:34:32.035: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.4.14.201
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Aug  1 18:34:42.035: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Aug  1 18:34:42.035: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'WLAN_EstrellaR'running version 7.0.220.0 is rejected.
*Aug  1 18:34:42.035: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Aug  1 18:34:42.035: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Aug  1 18:34:42.035: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Aug  1 18:34:42.035: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.4.14.201
1 ACCEPTED SOLUTION
VIP Purple
Re: WLC 2504 with AP 3502
Hi Martin
U need atleast 7.1.91.0 version on controoler .
3600 series AP  first suppourt is
CAP3602I
7.1.91.0
Update firmaware on wlc.
also paster sh sysinfo from WLC.
matrix compatibiolity: http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
VIP Purple
Hi Martin
CAP3602I
7.1.91.0
ok, try to do upgrade and confirm the results, thanks.
Thanks, sandeepchoudhary21.
VIP Purple
Can u please mark this question as answered, it may help others.
Don't forget to rate helpful posts
307
