WLC 4402 + N7K vPC
Does anyone know if WLC 4402 LAG will work over a virtual port channel to two N7Ks?
1 REPLY
Re: WLC 4402 + N7K vPC
I don't know about Nexus. What is a fact is that it can't work usually when plugging ports on different switches.
It does work with VSS because the 2 switches can act as 1. So if the Nexus is able to build the portchannel across the 2 nexus and is able to balance the packets with "src-dest-ip" load balancing, then yes it will work.
Actually the WLC doesn't negotiate or doesn't do anything special than sending back traffic from where it came from.
HTH,
Nicolas
If     this helps you and/or answers your question please mark the question    as  "answered" and/or rate it, so other users can easily find it.
606
