WLC 4402 port 2 is in mirror state
Facing strange issue with controller 4402 WLC. Using port 2 for the guest network connectivity. User complaint that they are not able to access internet. I  found that they are not able to reach their gateway whcih is on firewall. Checked the port status on the firewall and it showing yellow and port status on controller is green. Changed the cable and port on the firewall  but still the same status.
Connectivity is explained below
controller port 2-> firewall ->internet.
After changing the cable and port noticed  that mirror mode on port 2 of the controller is enable. Not able to disable that mode. Screen shot is attached. I am sure there is some bug related to it but didn't find any. has someone any idea?
Product Identifier Description AIR-WLC4402-25-K9
Software Version 6.0.199.4
1 REPLY
Re: WLC 4402 port 2 is in mirror state
www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/c60mint.html#wp1145963
Rating useful replies is more useful than saying "Thank you"
223
