WLC 4402 with Ap 1131Ag Urgent
Im trying this frist time and gone through the documenet during the installtion.
I have configured the WLC 4402 as below
(Cisco Controller) >show interface summary
Interface Name Port Vlan Id IP Address Type
ap manager 1 2 52.234.57.132 Dynamic
management 1 untagged 52.234.57.8 Static
service-port N/A N/A 192.168.1.1 Static
virtual N/A N/A 1.1.1.1 Static
(Cisco Controller) >show interface detailed management
Interface Name................................... management
MAC Address...................................... 00:21:a0:38:69:80
IP Address....................................... 52.234.57.8
IP Netmask....................................... 255.255.255.128
IP Gateway....................................... 52.234.57.3
VLAN............................................. untagged
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 52.225.1.2
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
But after onnecting my APs im getting an error...
*Mar 1 00:18:48.839: LWAPP_CLIENT_ERROR: lwapp_name_lookup - Could Not
resolve
CISCO-LWAPP-CONTROLLER.hyderabad2.XXXX.com
Translating "CISCO-LWAPP-CONTROLLER.hyderabad2.XXXX.com"...domain
server (52.2
24.13.1) (52.225.1.2)...
Can you please help me .. to solve this
Re: WLC 4402 with Ap 1131Ag Urgent
I will assume you are using DNS to find the controllers?
Did you enter the A record in the DNS server to the management IP address of the controllers?
From your PC ping CISCO-LWAPP-CONTROLLER and see if you get a response from the controller.
If you are using DNS and it responses back properly to your PC. Then check your vlan in which the AP sits to make sure its config properly.
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
If you choose not to use DNS you can use Option 43 for DHCP or manually enter in an IP address and controller IP address for each AP from the console port.
Can you tell me what will be the best way to configure my WLAN setup.
Our set up is
1. 2 Cores switch 4506 with HSRP 52.234.57.3/25 (MNGMT VLAN 1)
2. 52.234.57.128/26 (For WLANusers VLAN 2)
3. C 3750 PWR in Access 52.234.58.0/24 USER1 (VLAN4)
4. C 3750 PWR in Access 52.234.59.0/24 USER2 (VLAN5)
Our DNS and DHCP server sits in HO with IP adrs 52.225.1.2 and 52.234.15.12.
I have did the basic WLC configuration.
and when i connected the LAP in my access i found the error of NOT able to resolve with DNS server. i.e CISCO-LWAPP-CONTROLLER.hyderabad2.XXXXX.com.
I'm getting this error when try both L2 and L3 setup.
Please advice how to overcome this.
Thanks in advance...
Vj
Our set up is
We are using C4402 WLC and 1131 AG LAP
Vj
Hall of Fame Super Gold
Can you ping CISCO-LWAPP-CONTROLLER.hyderabad2.XXXXX.com from:
1. Your PC; and
2. Your AP
Can you try the command:
lwapp ap controller ip add
No im not able to ping....
and yes
I added that command in AP.
Im getting a error in AP while booting with WLC
Mar 1 00:01:33.467: LWAPP_CLIENT_ERROR: lwapp_name_lookup - Could Not resolve CISCO-LWAPP-CONTROLLER.hyderabad2.XXXXX.com
Translating "CISCO-LWAPP-CONTROLLER.hyderabad2.XXXXX.com"...domain server (52.224.13.1) (52.225.1.2)
Pls help
Rdgs,
Vijay
The management interface and the AP manager interface must both be tied to physical port one and the switch port they are attached to must be trunked so that traffic from other VLANs can get to them. Then, the APs must be able to get to the management interface. First, they must get an IP address either from a DHCP server or helper on that LAN segment and VLAN or statically assigned. Then they must be able to get to the management interface, by DHCP Option 43, DNS, or manually configured at the CLI for the AP. You could be blocking them with a ACL or firewall but I doubt it. Sounds like a routing issue.
Hall of Fame Super Silver
Your management and ap manager needs to be on the same vlan identifier set to "0". Looks lik eyour ap manager is configured for vlan 2.
Make sure the trunk port that port 1 is connectred to is configured for native vlan
-Scott
Scott,
Where do you see tagged for 2 on is AP Manager? I thought it was untagged. By the way, with the new CAPWAP code AP managers are a thing of the past. Finally!!!! Never mind. I see it. Yep. That would be his problem.
Dennis - Can you elaborate on the CAPWAP and AP Manager statement. Are you saying the AP manager interface is no longer necessary in 5.2?
When running full CAPWAP no AP Manager interfaces are needed. That will be fully supported in 6.0.
Yeap i made all the changes as per the discussion.
My WLC is in VLAN1 52.234.57.7/25
Ap manger 52.234.57.8/25
I mannualy given the IP address for LAPs
52.234.57.132/26 for 4 nos wich will be in VLAN 2 with a default gateway 52.234.57.131.
Now im able to communicate from AP to my network.
But still im not able to connect my PC to network or i'm not ableto ping Ap from my PC
I have given a static Ip 52.234.57.145/26 in my pc
I have created an SSID and made my PC to sync with Aps .
the result is , the PC is not able to ping APs IP address ,WLC or any gateway.
Is there any setup to be done to make PC and APs to talk.
both AP and PC in VLAN2
Any suggesions
Pls help.
Vj
Make sure that you allow static clients access to the WLAN. If you have dhcp required enabled you won't be able to get on the network.
Hi Dennis,
I have tried in ether way, but not happeining.
Can you tell me...
After Basic WLC and LAP setup.
What will the next step to connect PC to WLAN.
I mean SSID, WEP... etc does this affects
The only problem im facing is , not able to connect my PC to WLAN.
regards,
Vj
476
