09-12-2013 10:02 AM - edited 07-04-2021 12:49 AM
Hello!
Yesterday's power off. After turning on the controller wlc 4404 does not boot.
On the console, we get the following:
Net:
PHY DEVICE : Found Intel LXT971A PHY at 0x01
FEC ETHERNET
IDE: Bus 0: OK
Device 0: not available
Device 1: not available
Booting Primary Image...
Press <ESC> now for additional boot options...
Error (no IRQ) dev 0 blk 0: status 0x51
Error reg: 10
** Can't read from device 0 **
** Unable to use ide 0:4 for fatload **
Error reg: 10
bzImage Image Integrity Check Failed(Bad Magic Number). Hanging
Apparently damaged flash. I have new CF256Mb.
There are ways to recover?
Solved! Go to Solution.
09-13-2013 04:34 AM
Then there isn't much you can do, because you would probably have to RMA it. I think they are end of support also so you wouldn't be able to purchase a support contract.
09-12-2013 03:45 PM
Do you have a valid Service Contract to RMA the appliance?
09-13-2013 01:31 AM
No End User havn't Service contract.
09-13-2013 04:34 AM
