Community Member
WLC 5508 and 1142 APs
Hi ! How can I view the WPA passwords that was set on my APs ? I have web access to the WLC. Thanks.
Hall of Fame Super Silver
You can't.... if you have a WIndows 7 machine on the network, you can view the password there.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
You can use a program called wz Cook on windows boxes to pull the wep and wpa keys ..
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Community Member
I am referring to the web gui of the WLC 5508.
You can not. Scott is right you can see the key only in computer that are already join to the network.
As per your query i can suggest you the following solution-
Sorry, you cannot view the WPA passwords that was set on APs .
Hope this will help you.
205
