Community Member
WLC 5508 and LAP1131AG-A-K9
I have an AP acting a little crazy it won't join the controller after a reboot and it forever loops the blue text after boot up. The controller is reachable by any other AP I plug in. The only thing different with this AP is I tried to configure the IP address settings from the command line instead of the controller gui I've since cleared the static IP and it still won't boot up properly and join. I'm not sure the what the red text is up to. Please let me know if theres any more information you need.
cisco AIR-LAP1131AG-A-K9   (PowerPCElvis) processor (revision B0) with 25590K/7168K bytes of memory.
Processor board ID FTX1446N021
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 7.0.98.0
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 58:8D:09:EA:B3:F2
Part Number                          : 73-8962-14
PCA Assembly Number                  : 800-24818-13
PCA Revision Number                  : A0
PCB Serial Number                    : FOC144320M0
Top Assembly Part Number             : 800-29144-03
Top Assembly Serial Number           : FTX1446N021
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1131AG-A-K9
hostname
% Incomplete command.
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:05.848: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:07.464: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:09.062: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:09.160: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 425 messages)
*Mar  1 00:00:09.190:  status of voice_diag_test from WLC is false
*Mar  1 00:00:11.297: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:11.362: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1130 Software (C1130-K9W8-M), Version 12.4(23c)JA, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 01-Jun-10 13:18 by prod_rel_team
*Mar  1 00:00:11.362: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:00:11.442: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:11.620: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:11.620: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:11.620: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:12.307: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:12.622: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:12.622
User Access Verification
Username: : %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:00:19.744: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.101.10.97, mask 255.255.255.0, hostname ap
Username: Cisco
Password:
ap>en
Password:
*Mar  1 00:00:30.272:  status of voice_diag_test from WLC is false
*Mar  1 00:00:30.314: Logging LWAPP message to 255.255.255.255.
ap#
*Mar  1 00:00:32.131: %CDP_PD-4-POWER_OK: Full power - INJECTOR_DETECTED_PD inline power source
*Mar  1 00:00:32.171: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:32.214: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:33.132: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:00:33.133: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Mar  1 00:00:33.171: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
Translating "CISCO-CAPWAP-CONTROLLER.hpb.hpbrm.com"...domain server (10.101.1.10) [OK]
Translating "CISCO-LWAPP-CONTROLLER.hpb.hpbrm.com"...domain server (10.101.1.10) [OK]
*Mar  1 00:00:41.363: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:00:51.367: %CAPWAP-3-ERRORLOG:  Could not discover configured MWAR (Lab).
*Mar  1 00:00:51.369: %CAPWAP-3-ERRORLOG: Failed to join controller.
*Mar  1 00:00:51.369: %CAPWAP-3-ERRORLOG: SM handler: Failed to process timer message.
*Mar  1 00:00:51.369: %CAPWAP-3-ERRORLOG: Failed to handle timer message.
*Mar  1 00:00:51.369: %CAPWAP-3-ERRORLOG: Failed to process timer message.
*Mar  1 00:00:51.369: %CAPWAP-3-ERRORLOG: Discovery interval timer expiry handler failed.
*Mar  1 00:02:27.891: %CAPWAP-3-ERRORLOG:  Could not discover configured MWAR (Lab).
*Mar  1 00:02:27.891: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Not in Bound state.
*Mar  1 00:02:33.395: %CAPWAP-3-ERRORLOG: Failed to join controller.
*Mar  1 00:02:33.395: %CAPWAP-3-ERRORLOG: SM handler: Failed to process timer message.
*Mar  1 00:02:33.396: %CAPWAP-3-ERRORLOG: Failed to handle timer message.
*Mar  1 00:02:33.396: %CAPWAP-3-ERRORLOG: Failed to process timer message.
*Mar  1 00:02:33.396: %CAPWAP-3-ERRORLOG: Discovery interval timer expiry handler failed.
*Mar  1 00:02:36.409: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:02:36.522: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.101.10.97, mask 255.255.255.0, hostname ap
1 REPLY
Re: WLC 5508 and LAP1131AG-A-K9
reset it to factory default by using the mode button for example.
Nicolas
1442
