11-06-2011 07:09 PM - edited 07-03-2021 09:02 PM
Hi All,
I have purchased the following hardware with the following configuration:
WCS-PLUS-100 Cisco WCS with PLUS License
2 x AIR-CT5508-100-K9 Cisco 5508 Series Wireless Controller
One controller is in use for Corporate, the other is the Guest Access controller.
We are at a stage where I want to increase the AP device count. My question is am I able to transfer the license from the Guest controller across to the Corporate controller (as no APs are associated with the Guest controller) and, do I also need to increase the license on the WCS?
Cheers,
Dan
Solved! Go to Solution.
11-06-2011 09:53 PM
Hi Dan,
You will not able to transfer license from 1 controller to another.license is device based, you cant use the license of one WLC in another . You can get addittive license for 25 AP support ownwards. You can order based on your number of AP
Yes, if you want the AP to be monitored in WCS and if the AP limit hasnt reached
NikhiL
11-06-2011 09:53 PM
Hi Dan,
NikhiL
11-07-2011 02:35 PM
Thanks Nikhil,
Most appreciated!
11-07-2011 09:47 PM
