10-09-2013 02:28 AM - edited 07-04-2021 01:02 AM
Hello.
Can any one suggest me what is the optimum code for use in my controllers 5508 or HA. Can i use 7.4.110 or 7.5.102 ?
Dose code 7.5.102 include all features of 7.4.100 code ? Someone told me that there are parallel teems developing these codes with consequenses the code 7.5.102 do not include the features of 7.4.100 code. Can any one confirm this for ?
Thakns
10-09-2013 03:34 AM
My WiSM2 are running 7.5.102.0 with HA SSO. I don't see any problems.
10-09-2013 04:54 AM
Newer codes have more features than older code versions. This doesn't mean that maybe a feature has changed or been removed. You have to look at what features you need and go with a code version that fits your needs. The reason I say this, is because each code version comes with a list of bugs. You need to review the list and make your decision from that. Code versions also makes you have to have your MSE and NCS/Prime Infrastructure also at a certain code level, which can be costly. HA AP SSO seems better on v7.4.110.0 and v7.5. Don't think of it as the latest code is the best, because as far as stability on any of the v7.x code versions, v7.0.x is Cisco's most stable v7.x code train.
10-10-2013 01:33 AM
I will recommend 7.5.102.0 as it also supports L2 redundancy and has a bug fixed for silent crashes due to gateway unreachability.
10-10-2013 04:26 AM
I am running 7.4.100.0 for a few sites with 5508 in HA and there are no issues.
