12-17-2013 04:54 AM - edited 07-04-2021 01:26 AM
Is it required that the access points are in the same vlan as the management interface on a wlc 5508?
Solved! Go to Solution.
12-17-2013 05:56 AM
No, it's not required. So long as there is L3 reachability between the AP VLAN(s) and the Management interface that is what matters.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
12-17-2013 05:56 AM
HTH,
Steve
12-17-2013 06:19 AM
Steve is right.... just to add, here is a link to a doc that explains the AP join process in both layer 2 and layer 3.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806c9e51.shtml
Scott
Help out other by using the rating system and marking answered questions as "Answered"
12-17-2013 06:43 AM
One thing I will add. If you use the management interface and not an ap manger. Make sure under the management interface you check box dynamic ap manager.
12-17-2013 06:54 AM
Good point George... I keep assuming people don't change that:)
Scott
12-17-2013 06:56 AM
I assume the same for the Gen2 WLC.
HTH,
Steve
12-17-2013 06:57 AM
There is a story behind this .. Just yesterday my guy was like "aps wont join" .. I let him hammer away at it .. It was the check box
__________________________________________________________________________________________
"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
12-17-2013 07:11 AM
Your EVIL!!!!
Scott
12-17-2013 07:18 AM
The positive .. He will never forget it again!
