You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
WLC 5508 management port is not pingable!
I'm having an issue with the 5508 management port .. I can't seem to ping it from the switch connected to it .. ( the Show cdp command shows that the two can see each other .. but no ping is possible !
below is the details :
(Cisco Controller) >show interface summary
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
management                       7    103      192.168.103.10  Static  Yes    No
service-port                     N/A  N/A      192.168.102.11  Static  No     No
virtual                          N/A  N/A      192.168.167.11  Static  No     No
on the switch:
interface GigabitEthernet0/45
switchport access vlan 102
switchport mode access
interface GigabitEthernet0/46
description *** connected to WLC ***
switchport access vlan 103
switchport trunk native vlan 103
switchport mode trunk
speed 1000
duplex full
spanning-tree portfast
any suggestions ?
  • Getting Started with Wireless
Salam Ahmad,
The management port seem to be mapped to physical port number 7.
you need to have the port number 7 connected to the neighbor switch.
If you are using other than port 7 then it will not work.
Connect port 7 to the switch and test please.
Amjad
Rating useful replies is more useful than saying "Thank you"
Re: WLC 5508 management port is not pingable!
thanks dear for your reply.
it's connected to port 7 .. the switch and the WLC can see each other but don't seem to be able to ping each other!
(Cisco Controller) >show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater,
                  M - Remotely Managed Device
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
CORE-S1          Gig 0/0/7         175           R S I    WS-C3560X Gig 0/46
and also for more details:
(Cisco Controller) >show interface detailed management
Interface Name................................... management
MAC Address...................................... 64:9e:f3:bf:5f:c0
IP Address....................................... 192.168.103.10
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.103.252
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 103
Quarantine-vlan.................................. 0
Active Physical Port............................. 7
Primary Physical Port............................ 7
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 172.172.1.30
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
and the VLAN on the switch:
interface Vlan103
ip address 192.168.103.252 255.255.255.0
standby 103 ip 192.168.103.254
standby 103 priority 200
standby 103 preempt
any suggestions?
I am not seeing any problem so far with the config if you are pinging the management from the same VLAN.
There could be problems with traffic among VLANs because you are using the physical port ip address as the gateway on the WLC management interface. You should use the virtual IP instead.
Q. I connected my WLC to Cat6500 switches configured for routing, and I configured HSRP between these switches. However, I am now unable to reach other subnets through WLC. How do I resolve this issue?
A. When HSRP is in place, a virtual IP address and MAC address is usually configured for the HSRP group, which is used for routing. Hosts continue to forward IP packets to this consistent IP and MAC address even when one of the switches go down and change over to a standby device takes place. Complete these steps in order to resolve the routing issue:
-Make sure the virtual IP address is configured as the default gateway on the WLC.
     Note: Certain earlier versions of WLC do not forward packets to HSRP MAC address, which results in      failure to route packets. Upgrade the WLC in order to resolve this issue.
- Make sure the virtual interface on the WLC is properly configured. For more information on interfaces, refer to the Configuring Ports and Interfaces section of the WLC Configuration Guide.
Reference: http://www.cisco.com/en/US/products/ps6366/products_qanda_item09186a008064a991.shtml
Try using the virtual IP as a gateway (or remove hsrp config from under the interface) and check if that helps.
Amjad
Hall of Fame Super Silver
I would change your switch port config to this
switchport trunk allow vlan 103
spanning-tree trunk port-fast
You do not need the access port config and you are tagging the management vlan (103), so you need to just allow vlan 103 and any other vlans you map your clients to.
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
Thanks Scott,
This resolved the issue for me (had it too).
Have rated.
Cheers,
Brett
8359
