WLC 5508 Problem with #DOT1X-3-INVALID_REPLAY_CTR
Hi all,
I have WLC 5508 with version 7.4.110.0 and with 13 AccessPoints.So 12 of this AP are  AIR-LAP1142N-E-K9 and 1 is AIR-CAP3602I-E-K9.
Logs of my WLC are:
*Dot1x_NW_MsgTask_1: Jan 11 01:15:05.167: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client 90:c1:15:c6:c3:49 - got 00 00 00 00 00 00 00 01, expected 00 00 00 00 00 00 00 02
*Dot1x_NW_MsgTask_4: Jan 11 01:09:41.015: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client 5c:0a:5b:c1:16:34 - got 00 00 00 00 00 00 00 01, expected 00 00 00 00 00 00 00 02
*Dot1x_NW_MsgTask_3: Jan 11 01:03:32.269: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client 40:b3:95:13:da:cb - got 00 00 00 00 00 00 00 03, expected 00 00 00 00 00 00 00 04
*Dot1x_NW_MsgTask_3: Jan 11 01:03:32.266: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client 40:b3:95:13:da:cb - got 00 00 00 00 00 00 00 02, expected 00 00 00 00 00 00 00 04
*Dot1x_NW_MsgTask_0: Jan 11 01:03:31.648: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client 24:77:03:67:01:48 - got 00 00 00 00 00 00 00 02, expected 00 00 00 00 00 00 00 03
*Dot1x_NW_MsgTask_5: Jan 11 01:03:31.638: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client 14:10:9f:da:c1:cd - got 00 00 00 00 00 00 00 02, expected 00 00 00 00 00 00 00 03
*Dot1x_NW_MsgTask_2: Jan 11 01:03:31.638: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client cc:78:5f:29:cc:82 - got 00 00 00 00 00 00 00 02, expected 00 00 00 00 00 00 00 03
*Dot1x_NW_MsgTask_4: Jan 11 01:03:31.633: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client 08:11:96:55:81:c4 - got 00 00 00 00 00 00 00 02, expected 00 00 00 00 00 00 00 03
*Dot1x_NW_MsgTask_0: Jan 11 01:03:31.631: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client 84:3a:4b:56:36:50 - got 00 00 00 00 00 00 00 02, expected 00 00 00 00 00 00 00 03
*Dot1x_NW_MsgTask_1: Jan 11 01:03:31.630: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client 14:10:9f:e2:d4:91 - got 00 00 00 00 00 00 00 02, expected 00 00 00 00 00 00 00 03
*Dot1x_NW_MsgTask_0: Jan 11 00:59:52.593: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client a0:88:b4:60:20:f8 - got 00 00 00 00 00 00 00 01, expected 00 00 00 00 00 00 00 02
*apfRogueTask_3: Jan 11 00:59:32.168: #APF-1-UNABLE_TO_CONTAIN_ROGUE: apf_rogue.c:4414 Unable to contain rogue 40:01:C6:11:F9:F1 - Not enough Container AP(s). Number of Container AP(s) 2, Requested containment level 4
*apfRogueTask_3: Jan 11 00:58:38.635: #APF-1-UNABLE_TO_CONTAIN_ROGUE: apf_rogue.c:4414 Unable to contain rogue 40:01:C6:11:F9:F1 - Not enough Container AP(s). Number of Container AP(s) 1, Requested containment level 4
*Dot1x_NW_MsgTask_0: Jan 11 00:50:06.885: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client 10:68:3f:46:4e:e8 - got 00 00 00 00 00 00 00 01, expected 00 00 00 00 00 00 00 02
*Dot1x_NW_MsgTask_0: Jan 11 00:50:06.883: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client 10:68:3f:46:4e:e8 - got 00 00 00 00 00 00 00 00, expected 00 00 00 00 00 00 00 02
*dot1xMsgTask: Jan 11 00:49:05.842: #DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:618 Client c8:e0:eb:19:2a:97 may be using an incorrect PSK
*apfRogueTask_3: Jan 11 00:40:42.576: #APF-1-UNABLE_TO_CONTAIN_ROGUE: apf_rogue.c:4414 Unable to contain rogue 40:01:C6:11:F9:F1 - Not enough Container AP(s). Number of Container AP(s) 3, Requested containment level 4
*Dot1x_NW_MsgTask_3: Jan 11 00:40:17.471: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client c4:43:8f:f1:8c:8b - got 00 00 00 00 00 00 00 01, expected 00 00 00 00 00 00 00 02
*Dot1x_NW_MsgTask_4: Jan 11 00:40:03.368: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client f0:d1:a9:8e:1a:dc - got 00 00 00 00 00 00 00 02, expected 00 00 00 00 00 00 00 03
*Dot1x_NW_MsgTask_1: Jan 11 00:39:30.528: #DOT1X-3-INVALID_REPLAY_CTR: 1x_eapkey.c:360 Invalid replay counter from client 14:10:9f:d8:84:09 - got 00 00 00 00 00 00 00 01, expected 00 00 00 00 00 00 00 02
I already go to this link to check the Description of errors-
http://www.cisco.com/en/US/docs/wireless/controller/message/guide/msgs4.html#wp1000139
Appreciate all feedback. Thank you.
Hi Ruben,
a) After successful dot1x authentication, session keys are derived from pairwise master key.
b) When the AP transmits a key to a station by default, it expects a response back within a set timeframe.
c) If the station does not respond, the AP increments the counter and retransmits the key.
d) If the AP receives a response to first message just after the retransmission of the key, a mismatch occurs in the counter.
This in most of the cases will be a client driver problem.
Solution :
1) try to increase the EAPOL-Key Timeout ( config advanced eap ).
2) Upgrade the client driver.
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Regards Victor V *****Help out other by using the rating system and marking answered questions as *****Answered"*****
Thanks for your help victor
Hi Ruben, I'm getting the
Hi Ruben,
I'm getting the same messages in one of my customers.
Did you manage to solved this error messages?
Did you increased the EAPOL-Timeout? We have it configured at 400 milliseconds
Kind regards,
Vasco
Hi Vasco, First you need to
Hi Vasco,
First you need to check if you have IPV6 enable on your WLC.
If you have, so disable it.
Second Increased the EAPOL-Key - Timeout to 300 milliseconds
Finally, check your version of WLC and ensure that you have your software controller in ED version.
After that, problem solved.
Early Deployment (ED) —These software releases provide new features and new hardware platform support as well as bug fixes.
 Maintenance Deployment (MD) —These software releases provide bug fixes and ongoing software maintenance.
 Deferred (DF) —These software releases have been deferred. We recommend that you migrate to an upgraded release.
9117
