Community Member
wlc 5760 design
I have a new deployement with WLC 5760.
total number of aps are 150 with 4 WLANs.
each WLAN is mapped to a sperate VLAN. I have a couple of design questions:
     - the switchport configuration of the AP will be trunk or access ?
       if access, then port should be memeber of which VLAN ?
     - mobility configuration for single WLC design ?
     - I would like to make two groups in which group 1 will advertise WLAN 1,2 and 3 while the group 2 will advertise only WLAN 4.
       is it possible ?
really apprecite your response.
1 REPLY
VIP Purple
Re: wlc 5760 design
Here is my responses
5760 only support Local mode APs. So all your AP connected switchports (in access layer) should be configured as access ports. You can put that in a different AP management vlan.
You can configure a mobility group name even though no any other controllers.
     - I would like to make two groups in which group 1 will advertise WLAN 1,2 and 3 while the group 2 will advertise only WLAN 4.        is it possible ?
Yes, you can create two AP groups & map these WLANs. Then add APs into these two AP groups according to your requirement.
These posts should give you some reference
http://mrncciew.com/2013/12/16/5760-in-ca-cuwn/
http://mrncciew.com/2013/12/12/getting-started-with-5760/
http://mrncciew.com/2013/12/14/3850ma-with-5760mc/
Rasika
**** Pls rate all useful responses *****
108
