Community Member
WLC 5760 with AP1121G
Guys,
i´ve got a thing that for me it´s a little bit odd. I´m trying to make a workgroup with wlc 5760 and a 1100 AP in autonomous mode but all I get it´s this error in the AP.
*Oct  1 18:45:05.639: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: WPAIE not found and required
*Oct  1 18:46:03.639: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: Rcvd response from 0c68.03ea.4073 channel 11 8861
*Oct  1 18:47:47.639: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: Associating
the configurations are:
dot11 ssid TEST
   authentication open
   authentication key-management wpa
   wpa-psk ascii 7 1416000E0F0C2379747960
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid TEST
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role workgroup-bridge
bridge-group 1
bridge-group 1 spanning-disabled
and on the WLC 5760,
wlan TEST 7 TEST
no broadcast-ssid
client vlan 7
no security wpa akm dot1x
security wpa akm psk set-key ascii 0 arechi2013
session-timeout 1800
no shutdown
sho wlan name TEST
Security
    802.11 Authentication                      : Open System
    Static WEP Keys                            : Disabled
    802.1X                                     : Disabled
    Wi-Fi Protected Access (WPA/WPA2)          : Enabled
        WPA (SSN IE)                           : Disabled
        WPA2 (RSN IE)                          : Enabled
            TKIP Cipher                        : Disabled
            AES Cipher                         : Enabled
        Auth Key Management
            802.1x                             : Disabled
            PSK                                : Enabled
            CCKM                               : Disabled
    CKIP                                       : Disabled
Can some one help me out?
Everyone's tags (6)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
1121's are not supported.  Here is a matrix that show what is supported and whats not.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html#wp98682
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Scott
-Scott
Community Member
You are so right Scott,
it didn´t cross my mind to see if the WLC 5760 supported those APs.
David
Re: WLC 5760 with AP1121G
Well, there are two things... they are not supported if you are trying to connect them as a local or flexconnect ap.  If you are using them as a WGB, I know they work on a Unified wireless architecture, but have not tested them out in a converged access architecture.  One thing that was required on the WLC is passive client and you might have to also have that enabled on your 5760:
config t
wireless multicast
wlan
passive-client
Scott
-Scott
Community Member
Scott,
in the guide "Consolidated Platform Configuration Guide, Cisco IOS XE Release 3SE (Cisco WLC 5700 Series)" I don´t see the option for the passive client, even in the configuration section of the WGB.
But I don´t think that option will resolve my problem.
thanks
cannot associate: WPAIE not found and required" error is generally seen due to WPA2 miss configuration
but as mentioned by Scott as this AP is not supported with 5760 and hence you are not able to get this AP as WGB with WLC 5760.
Table 2     Cisco WLC 5700 Series Supported Products
Product
Platform Supported
Access Point
Cisco Aironet 1040, 1140, 1260, 1600, 2600, 3500, 3600
VIP Purple
You can't use Autonomous AP in controller environment. Apart from this AP model is not supported with 5760, even if you get a supported AP model, you should have lightweight image on that, if you want to manage it by WLC & want to act as an Access Point.
Are you are trying to associate this as WGB (ie Client) to a LAP which is managed by 5760 ? Then you should have a LAP already registered to this 5760 & your WGB will associate to that LAP.
Release notes stated, 5760 support WGB, so you should be albe to do that, if you are trying to achieve it under above condition.
http://www.cisco.com/en/US/docs/wireless/controller/3.2_0_se/release_notes/OL28115_3_2_se_rn.html
Pls confirm
Rasika
**** Pls rate all useful responses ****
Community Member
Rasika,
i´ve tried to follow this guide:
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080905cea.shtml
The WGB can be any Cisco Autonomous Access Point that supports the       Workgroup Bridge mode and runs Cisco IOS Software Release 12.4(3g)JA or later       (on 32-MB access points) or Cisco IOS Software Release 12.3(8)JEB or later.
On the wireless LAN controller, you should have software version       4.1.185.0 or later.
They say it can be done.
VIP Purple
Yes WGB will be always Autonomous AP. Infact it is acting as a wireless client (though it is AP) to your wireless network. So you required Lightweigth AP managed by 5760 to connect that client (or WGB AP)
Hope that clears
Rasika
Community Member
Rasika,
Maybe you were misleaded on my initial text but thanks on the reply.
regards,
552
