02-12-2014 01:15 AM - edited 07-05-2021 12:09 AM
I have a WLC 5760 and i did below configuration for WLAN:
wlan 3 85 GUESTS
client vlan 85
no security wpa
no security wpa akm dot1x
no security wpa wpa2
no security wpa wpa2 ciphers aes
session-timeout 1800
no shutdown
the ap is joined with WLC:
EFFAT-WLC#show ap summary
Number of APs: 4
Global AP User Name: Not configured
Global AP Dot1x User Name: Not configured
AP Name AP Model Ethernet MAC Radio MAC State
APAP16.0009.abdc 3702I 1616.9999.8888 3c12.f123.0000 Registered
* have changed the mac address
but still i am not able to get the WLAN on the wireless clients. SSID is been broadcasted but when scanned on the client i am not getting it.
02-12-2014 01:18 AM
Can you make sure the SSID is broadcasted on both radios? Maybe the client only has one radio, like 802.11b only, and the SSID is broadcasted on 802.11a.
Do you have AP Groups configured?
02-12-2014 01:21 AM
all the radios are enabled.
do i a have to manually assign the radios to the SSID you mean ?
02-12-2014 01:22 AM
Just make sure that the SSID is broadcasting on both radios. Also make sure the SSID is assigned to the AP Group which the AP is currently using.
02-12-2014 01:39 AM
how i can assign the SSID to the AP Group ?
i am using the default AP group and there is no option to add WLAN to the AP Group.
I have created a new AP Group and now i can add in the WLANs and APs to this group.
do i have to assign the radios to this new AP group as well ?
02-12-2014 01:50 AM
Add the AP into the AP Group.
Make sure the SSID is also in the AP Group.
02-12-2014 01:45 AM
Are you using any radius server ???
if yes then use this commands: aaa-override
Check this config :
Hope it ehlps.
Dont forget to arte helpful posts
02-12-2014 01:52 AM
i am not using radius server right now.
Is there a way to change the default-group configuration ?
i am not able to assign WLANs to it.
also the APs are joining in the default-group by default.
02-12-2014 02:02 AM
Which version you have on wlc ??
3.2 or 3.3 ??
paste the sh version command output.
02-12-2014 02:05 AM
Switch Ports Model SW Version SW Image Mode
* 1 6 AIR-CT5760 03.03.01SE ct5760-ipservicesk9 INSTALL
02-12-2014 02:30 AM
Cany you use this config:
wlan Guests 15 Guests
aaa-override ( once use this command then try without this command
broadcast-ssid
client vlan 85
no security wpa
no shutdown
Try this, I have a doubt that your first line of the config have issue.
Dont forget to rate helpful posts
02-12-2014 04:13 AM
it is working now.
the problem was not the WLAN config.
no wlan was assigned to the default-group. i created a new group and assigned WLAN and then the APs to it.
once both were assigned APs started broadcasting the WLANs.
thanks for the help guys.
02-12-2014 04:19 AM
Glad that you got it working.
Thanks for giving the correct solution here. ---> +5 Point
Dont forget to rate helpful posts.
02-12-2014 11:03 AM
This post also should help you on this topic
http://mrncciew.com/2013/12/16/5760-in-ca-cuwn/
Rasika
**** Pls rate all useful responses ****
