wlc 5760 - wlan configuration
I have a WLC 5760 and i did below configuration for WLAN:
wlan 3 85 GUESTS
client vlan 85
no security wpa
no security wpa akm dot1x
no security wpa wpa2
no security wpa wpa2 ciphers aes
session-timeout 1800
no shutdown
the ap is joined with WLC:
EFFAT-WLC#show ap summary
Number of APs: 4
Global AP User Name: Not configured
Global AP Dot1x User Name: Not configured
AP Name                           AP Model  Ethernet MAC    Radio MAC       State
APAP16.0009.abdc                  3702I     1616.9999.8888  3c12.f123.0000  Registered
* have changed the mac address
but still i am not able to get the WLAN on the wireless clients. SSID is been broadcasted but when scanned on the client i am not getting it.
Hall of Fame Super Gold
Re: wlc 5760 - wlan configuration
Can you make sure the SSID is broadcasted on both radios?  Maybe the client only has one radio, like 802.11b only, and the SSID is broadcasted on 802.11a.
Do you have AP Groups configured?
all the radios are enabled.
do i a have to manually assign the radios to the SSID you mean ?
Just make sure that the SSID is broadcasting on both radios.  Also make sure the SSID is assigned to the AP Group which the AP is currently using.
how i can assign the SSID to the AP Group ?
i am using the default AP group and there is no option to add WLAN to the AP Group.
I have created a new AP Group and now i can add in the WLANs and APs to this group.
do i have to assign the radios to this new AP group as well ?
Add the AP into the AP Group.
Make sure the SSID is also in the AP Group.
VIP Purple
Are you using any radius server ???
if yes then use this commands: aaa-override
Check this config :
http://www.cisco.com/c/en/us/td/docs/wireless/technology/5760_deploy/CT5760_Controller_Deployment_Guide/Secure_WLAN_Configuration_on_Catalyst_3850WLC5508.html
Hope it ehlps.
Dont forget to arte helpful posts
i am not using radius server right now.
Is there a way to change the default-group configuration ?
i am not able to assign WLANs to it.
also the APs are joining in the default-group by default.
VIP Purple
Which version you have on wlc ??
3.2 or 3.3 ??
paste the sh version command output.
Switch Ports Model              SW Version        SW Image              Mode
*    1 6     AIR-CT5760         03.03.01SE        ct5760-ipservicesk9   INSTALL
VIP Purple
Cany you use this config:
wlan Guests 15 Guests
aaa-override ( once use this command then try without this command
broadcast-ssid
client vlan 85
no security wpa
no shutdown
Try this, I have a doubt that your first line of the config have issue.
Dont forget to rate helpful posts
it is working now.
the problem was not the WLAN config.
no wlan was assigned to the default-group. i created a new group and assigned WLAN and then the APs to it.
once both were assigned APs started broadcasting the WLANs.
thanks for the help guys.
VIP Purple
Glad that you got it working.
Thanks for giving the correct solution here. ---> +5 Point
Dont forget to rate helpful posts.
VIP Purple
This post also should help you on this topic
http://mrncciew.com/2013/12/16/5760-in-ca-cuwn/
Rasika
**** Pls rate all useful responses ****
229
