07-10-2014 08:47 AM - edited 07-05-2021 01:12 AM
Hi everyone,
Wondering with someone out there have been connected Cisco WLC on Brocade Switches. I am doing it now but I am not responsible for the Switch side and don´t know nothing about brocade so far.
It would be great with someone has some tips to share with me.
Solved! Go to Solution.
07-15-2014 07:58 AM
I get involved in this too with project, but support for other vendor equipment is the key. Hopefully you can get help in regards to the switches.
Scott
07-10-2014 03:53 PM
Whatever your response is, go HERE.
07-12-2014 08:16 AM
Leo,
Thanks for answer, therefore, I am talking about Brocade Switches. The page I was redirected for shows information about Cisco switches.
Anyway, thanks for try to help.
07-12-2014 05:18 PM
Flavio,
The link Leo has in his post is the direction of what is typical in a Cisco environment. It is up to you to work along side your vendor "Brocade", to determine the correct setting on the switch side. Most of the time, you need to trunk the WLC port if you have more than one vlan you will setup on the wlc. Alos if you decide to LAG on the WLC, then you need to be able to setup an etherchannel on the Brocade switch that is similar to how Cisco switch is configured. I would reach out to Brocade for help on that if you are not familiar with how to configure the switches.
Scott
07-14-2014 11:35 AM
Hi Scott, I see. I was wondering if anybody has already fought against it someday. I am not responsible for the Switches in this project and I am in trouble in getting it done by our partner and was trying to help them. Any way, thank you guys for all.
07-15-2014 07:58 AM
Scott
07-15-2014 08:14 AM
I tried searching but could not find anything. Have you posted on the Brocade community forum? I would just use one port off the 5508 as a trunk because the LAG is where you might run into an issue. At least you can get it working I would think.
Scott
