Community Member
WLC and AIRONET AP1231
Hi everyone, i have a question, i'm trying to configure a WLC 5508 with an access point AIRONET air ap1231g-a-k9, this is possible or the model isn't supported by the WLC?? i read that only LWAP are compatible
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: WLC and AIRONET AP1231
You do need a service contract to download any image.  This is the image you need...
If you are able to download this, then you need to convert the ap from autonomous to lightweight.  Here are the directions for that:
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
It is up to code 7.0. It isn't supported past this rev.
Just to add.... here is the compatibility matrix you should keep handy:
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Scott
-Scott
Community Member
then I only need upgrade to 7.0, the WLC is actualy in 6.0, isn't necesary change autonomous ap to lwapp.? another question. I need a service contract to download software from cisco's page.?
Scott
-Scott
Bronze
you must change the aIOS image to lwapp/capwap ap, which uses k8 image
Community Member
thanks to all, it was helpful, questions answered.
426
