WLC and AP 802.1x fails
Hi all,
I am trying to gather some information on how to pin point the issue that we are facing with.
after creating a new WLAN ID (same as BODY) which is applied to the same interface as BYOD interface the APs are sometimes associated with the new WLAN ID for a short time. then it get disconnected. with following
Exclusion reason : 802.1x failed
I have to mention, BYOD works fine.
I have deb the aaa all and could not see any valid information there.
any idea what i could do next
ps also ran the following without any indication to the AP Mac address
deb mac add <add>
deb capwap event
deb capwap error
any other ideas?
thanks in advance
Lance
  • Getting Started with Wireless
Bronze
 Hi, to make it simple, just
to make it simple, just get a debug client <MAC> and look into the logs after the EAP challenges, you should see the following
-access-accept
or
-access reject
or
-access challenge
if you get access-accept, then everything is fine with the .1x
if you get reject, check your AAA server logs and the supplicant configuration
if the issue appears after access accept and the clients disconnect the logs might show you why "you need a timestamp"
for the .1x exclusion, it seems that the client is using wrong credentials multiple times and the WLC block it to prevent the AAA queue to be full.
Gold
Please refer to the link-http
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-2/configuration/guide/cg/cg_lwap.html
debug client mac address is
debug client mac address is needed to solve  the problem and its not possible that radius auth is failing and BYOD is working..
104
