WLC and AP Compatible?
I have a rather basic question
We have obtained a WLC4136-K9 controller and a AIR-LAP1252G-A-K9 access point (with power injector - AIR-PWRINJ4). I'm having a heck of a time trying to get the AP seen by the controller and also am having trouble with the AP constantly rebooting. I'm getting traps on the controller webpage saying tha the AP is not supported on the controller.
So, my question is: Are these two devices compatible with one another? If not, is there a way they could be make to work with each other?
Phil
  • Getting Started with Wireless
2 ACCEPTED SOLUTIONS
@Leo, the 4136 is an origianl Airespace controller.
@Phil, I don't believe the 41xx goes beyond 4.1 code and the 1252 needs at least 4.2 code to work.  So you would need to find a 210x or 440x at a minimum, to get that AP to join.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Yup, 4.1 is where they stop. In fact I have 4 old AS controllers. I have the one that looks like a 24 port switch and the other ones look like a 4402 but with one SFP. And the SFP are plastic ..
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Hall of Fame Super Gold
4136 controller?  Never heard of this model before.
What firmware is your controller running?
Steve
Oh wow!  The original one.
Ok thanks guys. Not what I wanted to hear but at least I know where I stand now.
I only heave one AP (AIR-LAP1252G-A-K9) at the moment so it seems like a controller is a bit of an overkill.
So, now I'd like to use this AP as a standalone unit. I assume this means loading different code to make it "autonomous"... Is this correct? Where does one find the file and instructions for this?
Phil
Yes, you can download the autonomous image from (cco login / smartnet required):
http://www.cisco.com/cisco/software/type.html?mdfid=281235915&catid=null
Once you have an autonomous image you can follow these instructions:
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp161272
388
